Which braid and fluorocarbon for Shimano Sidestab 2500?
Vades
After losing some line on Saturday, and then managing to spool myself when casting on Sunday (lol), I think it's time to upgrade my line.
I am currently using a Shimano Sidestab 2500RE and would like to switch over to Berkley Fireline.
Which variant should I go for?
My fluorocarbon leader will be about 1m as my rod eyes are not large enough for knots of any type. What diameter leader should I be using?
Specs:
Model: SI2500RE
Line Retrieve Per Crank (in.): 29
Line Capacity (# Test/Yards): 6/200, 8/140, 10/120
Max Drag (lbs.): 7.0
Ball Bearings: 3
Roller Bearings: 1
Gear Ratio: 5.2:1
Weight (oz): 9.5
neilg
Theres a few
I use white, pink, black and green in Fireline
U can also look at Jerry Brown (much cheaper and a very good line) or Stren
I prefer 8-10lb
Prefer white or green
The Moose
I use suffix floro, 0.50mm (in case skippies are around) cost about R70.
And look at the Power Pro Braid. I got it at the Shop in Forrie for R200 for 300m of 15lb.
Vades
I settled on Berkley Fireline, 8lb, green.
Went for a quick throw and wow, what a difference in casting and feel!
