When making a bite trace,i'v used a figure eight with an overhead knot on the steel, as well as 2 figure eights to join a piece of 200lb bleeding red leader wire,with no problems..however, i'm having difficulty joining it using the albright,which is a much neater knot...the wraps(4-5) of the nylon just don't seem to tighten & slide down right to the tag end..is the steel/nylon (.85-1mm) too thick? ..any help would be appreciated.
