Elf,my setup is 12ft Loomis HMG ,TOR14 with .40 iso flourine line,ideal for handling stumpies,hell it even landed me my pb kob. Did you ever note that the thinner the line diameter is when fishing in windy conditions ,the less bow you have in your line !!
PREFER USING A 3 OUNCE BUT ROD RATED 5 OUNCEwhalerider wrote:Elf,my setup is 12ft Loomis HMG ,TOR14 with .40 iso flourine line,ideal for handling stumpies,hell it even landed me my pb kob. Did you ever note that the thinner the line diameter is when fishing in windy conditions ,the less bow you have in your line !!
yip..... what size sinker do u cast with?
running trace, fix trace...... sorry for the dumb ? but im new to this light tackle stuff!Elf 786 wrote:PREFER USING A 3 OUNCE BUT ROD RATED 5 OUNCEwhalerider wrote:Elf,my setup is 12ft Loomis HMG ,TOR14 with .40 iso flourine line,ideal for handling stumpies,hell it even landed me my pb kob. Did you ever note that the thinner the line diameter is when fishing in windy conditions ,the less bow you have in your line !!
"light tackle"
Depends on conditions,for galjoen in reefs i usaully go fixed trace,for stumps sliding trace keeping the mainlaine slack for it to slide in current (langebaan).when using a 4 ounce sinker i usually make the trace with .45 of .50 line for the longer cast !whalerider wrote:running trace, fix trace...... sorry for the dumb ? but im new to this light tackle stuff!Elf 786 wrote:PREFER USING A 3 OUNCE BUT ROD RATED 5 OUNCEwhalerider wrote:Elf,my setup is 12ft Loomis HMG ,TOR14 with .40 iso flourine line,ideal for handling stumpies,hell it even landed me my pb kob. Did you ever note that the thinner the line diameter is when fishing in windy conditions ,the less bow you have in your line !!
Hiya Guys,
A light tackle R&S set up for me is the following.
(BoomBoom does not agree, but thats fine! LoL)
3-4 oz Custome WaveRunner 11ft
GrandWave 20
50lb0.32mm Braid
0.50 Leader (9m)
0.40 - 0.50mm Hook Snoods
Any thinner line on a multiplier leads to trouble. Some might say that 50lb braid is not LIGHT, but the leader and trave mono dimeters certainly make things fun!
Trophy wrote:Hiya Guys,
GrandWave 20
50lb0.32mm Braid
0.50 Leader (9m)
Any thinner line on a multiplier leads to trouble. Some might say that 50lb braid is not LIGHT, but the leader and trave mono dimeters certainly make things fun!![]()
