*** What would you consider as 'light tackle' ***
Elf 786
i've been using loomis and assasins 14ft and 13.8 ft respectively and have scaled down from torium 30/ sl 50 to Tor 20 and sl30's........ soon to get me a tor16
Now the main question is what would one consider or when can one say that u using light tackle?????????? i dont own a coffee grinder and would probaly only get one if my laaitie is old enough to stand on his own.
is it the diam of line/ the rod/ the reel a combination of both????
if i use a sl30/tor20/ with 0.4 line paired with a 13.8ft rd, is this light tackle?
BoomBoom
I would definately say its all the above - Light tackle is exactly that ! Tackling down ! Tackle which would give a fish a fighting chance , and requiring more skill to land fish !
Putting 50lb braid or whatever does not classify it as light due to diameter, because that is infact heavy with the benefit of thin diameter!
John0
Yes sasaa considers .40 line or thinner as light tackle!!! You can use a tor50 and a 8+1 rod as long as you use .40 line or thinner it is light tackle!!! But if you ask me anything thinner than .45 is light tackle!!!
Elf 786
hi boomboom
would u consider a tor 16 loaded with 0.35 mono paired with a 12ft loomis as light tackle......? that's my next set-up but it seems more like a medium set-up , lol
Elf 786
nou daai is wat ek van praat..... THANKS !
Koper
Elf, wa gaat jy 'n Tor16 in die land uitstiek, jy meen nie 'n Tor14 nie?
Ek het darem lank gekyk vir een en hulle word mos nie in Suid Afrika versprei nie.
BoomBoom
hi boomboom
I would say ! I see it takes 320yds of 20lb mono ! and 450yds of 15lb
Elf 786
my bad , it is a 14...... a 16 would have been something i tell you!
Koper
Agreed - 14 not bad at all thought, gonna pair mine with a 11ft purglass
jaccil
For me...
Heavy - GW40/SL50/TN30 and bigger with 0.50mm or thicker on a /3 and heavier or a 8000+ grinder with 50-80lb braid.
Medium - SL30 with 0.35-0.45mm on a /1 or /2 or a 5000-8000 grinder with 20-50lb braid
Light - Anything smaller than above. Usually a 1000-4000 grinder with 6-15lb mono or up to 20lb braid.
Ultra-light - 2000 or smaller grinder with at most 6lb mono.
Now where would you fit this combo: Saltiga Surf 30 loaded with 0.45mm (80lb) braid paired with a rod that's equivalent to a /1! I'd actually prefer using 0.35mm (50lb) braid but it doesn't have enough abrasion resistance to fish the areas/conditions where I use this galjoen hunting kit.
Moeghoes
Basically depends what fish your targeting.
Light tackle for Big spotties, would be a 10 ft 3oz dropshot rod with a 4000 size grinder.
For blacktail stumpies and other reef species I would say anything lighter than a 7ft 1/2oz stick with a 2500 size grinder is light.
So its all relative...
Basically if your never getting busted up, your fishing to heavy... Keep playing around with the lighter set-ups. You'll be surprised how much more fun/rewarding it can be...
I've caught plenty (what most would call average catches) on a 1/16oz 5ft super ultra light of the bricks with 0.18 mm mono and a 1000 size grinder(Little big for the rod but you need the extra capacity). And to be honest some of those catches are my most memorable... One of which was a 40 minute fight with a 4 kilo White steamer.
Joker
Good question Elf786
I've often wondered why some guys fish with a sl50 and .50mm mono to target edibles. Hehe I used to do the same though.
My current set-up is KF lite with a sl30 and XX .42mm. For Gallie the reel and mono remains the same but a 110H.
Fluffy
light tackel....
anything below a stroke 6 HMG,
any reel smaller with less line capacity then a Torium30....
whalerider
Elf,my setup is 12ft Loomis HMG ,TOR14 with .40 iso flourine line,ideal for handling stumpies,hell it even landed me my pb kob. Did you ever note that the thinner the line diameter is when fishing in windy conditions ,the less bow you have in your line !!
