what reel?
eviltoy
hi guys. So i have an adrenalin extreme 12' what reel should i pair with it i was thinking a penn battle 8000 what do you guys think?
Jacquesdw
Have a look at the Fin-Nor Rampage 6000. Very budget price and super strong construction with 4BB and can take braid as well. Looks like a contender with the Diawa BG series.
G
Guest
Guest
Hello Eviltoy
If you looking in the Penn range the Conquer to me is where their value starts.
Shimano has a number of options but the best value reel would be a Stradic. I am not too familar with the Adrenalin rod but my guess would be that a 6000 size would fit nicely. Other Shimanos to consider would the the Sustain and Saragosa. Saragosa is a very strong reel. Only downside is that it only comes with 1 spool and a new spool is about R 750.
Daiwa has some options but the Seagate is where their quality starts. There are mixed reports on the others that fall into the lower price barcket. The Seagate has a ratio of around 4.8:1 which is not the fastest. It is a good strong reel for fishing bait or vertical jigging but you have to wind your arms off to keep a plug on the surface. For bait fishing Daiwa also have a number of options. I think there is an Emcast and an Emblem Pro. I have not owned one of these so I cannot comment of their suitability.
There are a few others to look at like the Abu Garcia Soron, the Okuma Salina and Mitchell Avocast. I would however stay with the tried and tested brands. My firm recommendation is the Shimano Stradic 6000.
Regards
Anton
eviltoy
hmmm im not a fan of finnors had a bit of an issue with 1 of the 2 i had so i tend to steer away from them. Once bitten twice shy. With regards to the stradic i had a look at one and it seems like a winner but the penn just feets better built to me. Tough choice this is as i will be using this as my primary eds setup for the season
steve m
I have a baby stradic(2500) and love it awesome reel! havent caught monsters on it biggest was a vaalhaai of +-10kgs off a boat and lots of smaller elf,steenies, 1 or 2 grunter etc but sofar so good very very nice reel so the bigger ones will be just as good...
is it mainly for bait or spinning? also look at the shimano ultegra also very very nice!
For mainly bait fishing then the Shimano Ultegra 5500 with some spare spools. 1m+ line retrieved per crank
eviltoy
Ok so I got myself the Ultegra CI4 5500 and put 300m of spiderwire ezbraid 50lbs on. Also added a braided leader.
Reel is very smooth. Leader going through eyes not so smooth so removing the leader as I mainly fish on sandy areas.
BTTB
I was fishing recently up at Henties and my favourite set-up was my Shimano Exage EXSF100 paired with the Daiwa Saltist 4500 using 30Lb Powerpro braid.
You could feel everything with that rod. I couldn't cast very far, but for the fish there you just need to throw over the first or second breaker in most places. It handled all the fish I caught with ease, the largest being a cob of about 20lbs.
For protection and to add some abrasion resistance look to add a Fluorocarbon leader. Use a leader that is short and doesn't run through the guides ie from outside the tip guide to the swivel connecting the trace.
50lbs is plenty strong. I personally would have gone with 30lbs - to put it into perspective and to compare apples with apples
Your 50lbs is equivalent to 0.65mm nylon whereas 30lbs is equivalent to 0.50mm nylon and 30lbs braid casts WAY further than 50lbs
Enjoy a really great reel
