Go with the .42 XX, 25Lbs. Not too thick and def not too thin. Casts like a dream.
If you go too thin, the line might creep in between the spool and the frame. Just depends on the finish of your reel.
Go with the .42 XX, 27Lbs. Not too thick and def not too thin. Casts like a dream.
Johan, my opinion of the reel.
Its not a bad reel at all, problem is the reel body is ill matched to the spool. There are/is irregular spacing between spool and reel casing. Too thin a line will enter into this space and get caught up within the reel often resulting in pinched line and then you will have to cut and remove and you eventually lose the line you have on the reel.
I have heard of comments from other torium 20 owners and looked at new models - all have the same issue. ?
:fishn
Â
Camo shortz
I use .32 on my saltiga 30.
There's no issue at all!!
Those reels you list(there may be others) have an issue dontchathink?
how many meters of the .42 do go onto the T20..??I have .42 XX on my tourim 20 and sl30 and it works perfectly.
