Two stroke oil
will101
I decided to buy bulk because getting 500ml pints every time at the yard gets expensive. Now I got 25l for R815 which works out to R33/l which is much better than R50/l or whatever. It's like a no-name brand though but looks, feels and smells exactly like the castrol or what have you I used previously.
Sure some oils have special additives but does it really matter? 2 stroke is 2 stroke right?
I spoke to Bernie at Mafuta. He recons the guys run normal 2-stroke oil, but once a year or 500 hours they run one tank with some or other blend that has a teflon in it. The teflon coats the moving parts and protects the cylinders.
will101
Thanks Bennie! Oil is not something you normally factor into running costs but after a few 60nm runs I'm starting to realize the oil cost.
cheers!
tkei
I always use shell nautilus. sure its not quicksilver or any of those, but its also not those prices. There is some difference between the 2 strokes, for bikes mowers and outboards. Try but y an outboard type. The yamahas you got probably dont care, just give them oil and they happy.
Dorado75
The commercials have been buying 2 stroke in bulk for years and dont seem to be complaining, so it should be just fine!
If you guys are interested there are a few petrol stations in the cape that give free 2 stroke depending on how much fuel you put in, the station in Glencairn gives one bottle for every 50 Litres of fuel you put in, I fill the bakkie up at the same time and then get oil for that too...... i have four strokes on the boat, so i am collecting the oil at home!
Rory
would you put no name oil in your new hilux? allways stuck to quicksilver but sure the other oil makers like shell must also be good
nautica
Look for a TCW-3 rating on the outboard oil . That seems to be the safe minimum spec rating that major outboard manufacturers require .
