Turbulence ShoreGame 11'
12' DC cut back works
110h Exage works, and please don't comment that the new differs from the old. It DOES NOT IT is the exact same blank
Purglas 330/4 works glass or carbon
FISH ASSASSIN
Hi Guys.
Quick one. What are we looking at for a fully built up rod? Fuji KR concept guides, Fuji winch,shrink grips? I already have a heavy Amia but am now looking at a Kob special for heavier lures. Sounds like this rod/ blank might be a better bet irrespective of cost.
One last question. With the action as described by Enigma, could I use this rod for small (one to two ounce) poppers as well?
Tackle-holic
When you say poppers, do you mean floating poppers or sinking plugs like GT Icecreams?
It will handle them just fine.
Throws a 1.5 or 2oz needle nose a very lonnnng way!
Sent you a PM
grootvis
I finally managed to hold and check out the a 12 ft Dc Oval.
Im quite impressed. It has fantastic tip recovery. I can now see where the 10.6ft can be utilised. Very nice rod.
I would love to get one or 2 of these built up.
Arno Nel
Grootvis, I wil let you know when I am in J-Bay again, then you can have a go with my dc 10'6" with the grinder
Arno Nel
FISH ASSASSIN wrote:
Hi Guys.
This rod will handle it
grootvis
Ive been trying to tell the Exage die hards this for ages...Not actually a great casting rod at all....Now, it might have lifting power, but weight and casting is negatives. I would definitely now rather consider a Dc oval or similiar over the Exage rods.
You have a nice rod there Craig in the Dc oval range. The 12ft would be perfect cob rod for throwing in the surf in my view.
Arno Nel
Grootvis, as mentoined. Next time I am in Jbay I will let jou know and you can test my dc 10'6 and shoregame 11'.
I use these rods for surf spinning
Tackle-holic
12' DC is silly good.
For its length, the distance it can cast is astounding.
Strong too.
grootvis
Craig. If you cut 2 foot from the 12ft dc. Would it be from the tip? If so, what would the tip od be then?
grootvis
Tackle-holic wrote:
Cut from the base, not the tip
Thanks!
An idea....a foot top and bottom? How would that pan out? Sorry probably wrong forum to post on. Just curious as to what action we would create and what oz lures we would be able to looi.
Tackle-holic
Craig might tell me off, I wouldn't cut the tip.
Tip dia is 3.2mm. (8/64ths ie #8 tube bore)
at 1' / 305mm back its dia is 4.9mm.
Think about that....
The 12' DC is a two piece when built, but you get the blank in 3 sections:
6' tip and 6' butt section made up of an oval tube that becomes round at its end  - you then insert butting tube into it with supplied thick wall carbon tube (its virtually parallel)
The 6' tip and the butt section without the butting tube will give you a 10' rod.
I will string up my 12' and hang a heavy weight on the end and take a photo so you can see the bend.
Tackle-holic
Loaded up with 24oz
The low angled shot is one with the rod butt in a pension pipe parallel to the ground, but the weight pulls the pipe out of the ground.
Arno Nel
Please add any info on this topic, it is interesting reading and always very interesting to see what the builders can cone up with to change the action of a rod
Schabies
Discovered these 2 brand new Graphcast blanks gathering
dust at my local tackle shop in Pretoria today! What a lekker find!
Time to pay Enigma a visit to convert them into something special....! 😀
