TRNIDAD 40
PLAYER 696969
HI
I WANT TO BUY A TRINI 40.
I NEED SOME HELP ON THESE QUESTION.
DOES IT THROW EASILY OR IS IT VERY HEAVY ON THE ROD?
WITH THE MAGNETIX DO U STILL GET ALOT OF OVERWINDS?
IS IT MAYBE TO BIG IN SIZE FOR THE ROD?
ANY OTHER INFO WOULD ALSO BE HELPFUL.
THANKS
Riaan_The_Legend
This is super vague! Give a little more info. Are you sliding/throwing, what rod, what line, all these things make a massive difference!
PLAYER 696969
well, i want to fish.
whether it's sliding or throwing bait.
i will be using my poseidon heavy 40 t, staffie.
i am in the market of buying a new reel.
like i said earlier i want to have some kind of idea what the reel up's and downs are.
i want to buy the saltiga 50 hyper, but if i can buy a cheaper reel doing the same function, why not.
i am actually comparing the 2 reels.
if i need to save a little bit longer to buy the saltiga ill do that. its only R 2 g diff between the two reels.
but i dont want to pay more if i dont have to.:wfish
Must-Byte
Hey Player while I don't have either reel I do know that with the price difference I would go for the trini. PM Kahn with his prices on the reel at the moment the difference is a lot more than 2k add a set of carbontex washers and the drag system should be similar in performance to the hypers actual performance (not advertised performance). I think the line capacity is slightly more on the trini as well it is also a narrower spool (again I could be wrong) so it should be easy enough to cast
Whaler
Hi, if i could make a sugestion, buy the trini 30 it is in the same class as the saltiga at half the price, the 40 is too big to fish comfortably with for most okes any way and is way more dificult to cast then the 30, i use  a 50 when fishing deap water points and a 30 when i fish the beaches! you could actualy buy both for the same price as the Hyper!
khan
Billy this is good advice, take it and use it!!
