Trini 30A
robyosh
Will try it but don`t think it would work to well as no stretch in the line therefore not easy to get bait down
Simen
robyosh wrote:
Braid is awesome and wont go back to mono
mate, some advice, use it or lose it
I only fish braid (except shark). Now to fill a reel with say 800m of braid if you are casting is a big foolish (not meant bad)
You will always only be using say the top 250m. When it frays or gets old then you simply turn it around on your spool.
Going this will leave a section of 300m unused braid in the middle of the spool.
What I do is.
Fill my spool with mono and just add 300m of braid as top shot.
When the braid frays or gets old I turn it around or later replace it.
Apart from being cheaper you actually get more life out of your braid.
I add 300m as you often cut bach say 2 to 3 m of line.
BigBen
What I do is.
Makes sense..Why load braid and 250mtr 'nylon' topshot..Very few if any edibles will take you to your braid...
Your braid then only serves to fill your spool.
dieterf
Simen what happens if you bunch with braid ? do you have to cut it out or can it come undone if you play with it ?
Psy
What I do is.
Eggzakly...((goodp_
When you get a kraaines with that 30A...mmmm then you cut it.
Been there done that.
Simen
To remove a "kraaines" (bunch up) from braid is much of a muchness as with mono.
The real difference between the two is that mono tends to bunch out (big loops) but braid tends to bunch in Small tight loops.
Where mono is then easy to pic with the fingers to find the cross loop, braid is tighter and I use a piece of wire with a small hook to help me find the cross loop.
Braid gets a while to get use to but as I say, I only fish braid and have since 1990/1
see http://www.sealine.co.za/view_topic.php?id=50871&forum_id=77
Strepie
my experience with braid is that it is easier to get sorted out as it stops much quicker when it does happen.
Simen
I can agree with that
