Gold_Shark
Hi Guys
I know this has been discussed before, but I need pictures to understand so here goes.
Lead too cool: Here is an example of a sinker that was poured and the lead was cooling to fast. Notice the large crack in the top of the sinker all the crevices in the finish. Not only is this an ugly sinker but it is also one that would break on the cast. To correct this I raised the temperature of the lead and the error went away. I also made sure the flow was correct as to lessen the cooling time and produce a better result.
Mold too cold: Here is sinker that was poured into a mold that was cold. Notice how the cavity only filled half way and the cavity opening filled. When molds are cold, the heat from the lead is absorbed by the aluminum and causes the lead harden before the cavity can be filled. This can be eliminated by pouring a few "warm up rounds" with the mold, it would have heated up the mold that it would have probably functioned properly. The walking sinker and a few of the other smaller sinkers are particularly susceptible to this problem. Always pour a couple trial sinkers to warm the mold before you begin your sinker production.
