[align=center]The Pirking Technique
[/align][align=center]
[/align][align=center] History[/align]
The pirking technique it’s a technique that exists for many years, since XVII century and consist on dropping a jig (pirk or zagaia) to the bottom zone and generate an up & down movement.
It’s commercial fishing origins start with the cod fish fishing with a handline with jigs known has lead pirks (or zagaias) of 12 to 15 centimetres long and with weights of 700 grams and more that were hand animated in a movement of up & down, trying to mimic of a wounded fish in depths from 40 to 80 meters.
Northern Europeans, Portuguese and North Americans were some of the fisherman that started to use this technique in deep waters to put cod fish at the table of many people around the world.
This is the much appreciated cod fish of the depths
[align=center]How it works[/align]
The principal of this style of fishing is to cast the pirk (jig), normally with an eel tied on a flyer above it (we will talk a little bit about this traditional eel or the more modern version of it the “dressed†assist hook), in the direction that the boat is drifting. This allows the tackle to be worked vertically for a longer time than the traditional down drift style of fishing,
The lures are generally cast from the updrift side of the boat, distances varying from 20 to 50 metres depending upon the weight of the lure and the speed of the drift. The faster the drift, the further the cast to ensure that the terminal tackle reaches the bottom while still on the updrift side of the boat. When the lure hits the bottom, it is retrieved with a lifting motion which takes in slack line as the boat drifts towards the lure.
The upward stroke of the rod is normally a sharp double jerk unlike the continuous sweep of conventional pirking, giving additional action to the lures. On occasions the fish will take only when the lift is very gentle with little movement of the jig, in this case most of the fish will come to the flyer rather than the jig.
The speed of the winding retrieve is dependent upon the drift speed.
It is essential to stay in contact with the lure at all times as fish strike not only on the upswipe but also as the jig falls to the bottom on the downstroke.
Where there are too many anglers aboard for everyone to fish from one side of the boat, those on the downdrift side can still work the small jigs effectively in the conventional manner. However, the amount of time actually spent fishing is reduced because the light lures move quickly from the optimum vertical position and this means more frequent retrievals and starting the cycle afresh.
Chrome Pirk
[align=center]Adaptation of pirking to modern jigging technique[/align]
This technique can be used in the modern jigging fishing, with braided lines, assist hooks and the variety of jigs actually available and this old technique has the potential to help us catch many bottom fish species.
The original pirks used to use hooks on the bottom of the pirk, but assist hooks on the top side of jigs can be used with the advantage of less hook ups in rocky bottoms.
The traditional eels that you see on this image
Can be replaced with assist hook "dressed" with lumo tubes , like these ones
The pirking technique is the grand father of what we call nowadays yoyo, and after the jig gets to the bottom lift it up a little and the movement can be:
*Moving the rod up and down very slowly
*Moving the rod up and down slowly
*Moving the rod up and down at medium speed
*Moving the rod up and down fast
*Moving the rod up with short jerks and then down
Try to cast your jigs from the updrift side of the boat.
The pirking technique can also be used in the bottom of the water column when there is fish suspend off the bottom.
Squid dressed assist hooks can also be used and like the lumo dressed ones will help us on this situation "On occasions the fish will take only when the lift is very gentle with little movement of the jig, in this case most of the fish will come to the flyer rather than the jig."
Squid skirts for the assist hooks
This technique can attract many fish that live near the bottom, like grouper, kob and many others.
Chrome Pirk
