THE OFFICIAL ACE-CRAFT FAN PAGE
ocean bounty
Hi Thika
The difference in handling is unbelievable, my previous 660 had twin ultra long 90 2-stoke Mariners, the difference between the two is really amazing. Just goes to show how various set-ups, although sometimes small make a massive difference. The 90's I had weighed in at 139kg's each and the 115's are in the region of 194kg's each, I find the boat more responsive in terms of handling and she doesn't seem to "hop"out the water as much as the previous boat. I think that is probably down to the fact that the boat has better weight distribution. But as you mentioned, the general maneuvering around the harbour is excellent, but the thing that impresses me the most is the stability. These boats have always had the "shits" taken out of them because they are "tender", well I think I might have found the answer, for me anyway. I have also taken the Bennett trim tabs off and trimmed them down(no pun intended), they were 350mm wide, you can probably trim the "Tafelberg" with that. So I cut them down to 240mm and moved them as far apart as possible. I have employed the simple rule that things of this nature are more effective the further they are apart. Net result "BINGO"works like a charm, once again much more responsive and the stability is brilliant. I looked at fitting the same kind of fins you have on your motors, but having got the boat with the Bennett's, it was more cost effective to stick with them. I must say, you must have one of the neatest 660's around, very nice.
Now if this bloody wind will stop blowing^^..
I will post a pic of the boat tomorrow.
Cheers Mike
thika
What?!!!
Trailer stolen already?!!!
Seriously though BFC...don't think you should have sold that boat so soon, but instead keep and tweak it until everything perfect
thika
ocean bounty wrote:
Hi Thika
Cheers Mike
Thanks OB!
The ONLY possible negative with the motors further apart, and I am not saying this will happen, is that with the leaning into a tight turn, the "upside" motor could be more prone to cavitate.
But then, how often do you really need to turn that tight in the Cape
This is a pic of Tailtime in just such a turn, courtesy of Skippy and his clan
Mouldz
thika wrote:
ocean bounty wrote:
Hi Thika
Cheers Mike
Thanks OB!
Lovely ,dont get that feeling in a cat:SSS
HelloC
Hi Thika,
Sorry to go slightly off the subject again, but after removing the carpets I noticed some delamination on the transom just above the floor - about 50mm wide and about 300mm wide on both sides of the main strut - the rot is only about 5mm deep though. So I opened the floor just to see how far this goes down, and noticed the one main beam also looks a bit suspect....so the way things are heading is a transom replace, the question is do you or anyone else perhaps know what type of wood they used on those beams? Looks like meranti possibly - but is there other "better" alternatives ?
ocean bounty
Hi Thika
Point taken, that was also my initial concern. However there proves to be no sign of cavitation in a tight turn, I have put her through some high speed hairpins, and nada nothing, so grinning from ear to ear.
Well looks like a trip to the deep on Saturday if the predictions hold, so currently got everything crossed.
And Mouldie, you are absolutely spot on, you can never experience that feeling in a cat. This is my thirteenth boat, I have owned a variety of mono hulls, but never owned a cat. I have skippered many cats and they are great boats and have there place. But I have never felt as safe and confident as I do in a 660DV, they are not the easiest of boats to master, but once you have it sussed they are truly fantastic.
Cheers Mike
HelloC
Hi Barryfish,
Thanks for the info, it is greatly appreciated. I quickly did some reading on Iroko and it definitely is the route I will follow
Tx again !!
BFC
The Youngest ACE is busy with its survey after its sea trials
fakawidan
Yes thanks man
i don't if you guy's know Oom Andre Olivier from Mapelane he use to have 3 motors this is his boat i bought 6 months ago and i think it came out grate only thing is i will only be able to go fishing in Feb 13 as i am still working in Kazakhstan an it is now -25 outside.
thanks for the support
here are more pic's for eady towing.
fakawidan
Yes thanks man
i don'tknow if you guy's know Oom Andre Olivier from Mapelane he use to have 3 motors this is his boat i bought 6 months ago and i think it came out grate only thing is i will only be able to go fishing in Feb 13 as i am still working in Kazakhstan an it is now -25 outside.
here are more pic's for eazy towing.
fakawidan
with cover
now that i look at the trailer it looks like it should be a dubble axel
thika
BFC,
You must take off those sunglasses when you punch da waves like dat hey!!!
I take my hat off to you:
How many okes have built their own boat from less than scratch?
:wfish:wfish:wfish
:ifishin:ifishin:ifishin!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
