[color=#ff6633]Trophy[/color] wrote:
Hiya Finnseeker,
No problem, I have joined 'Texas Shark Fishing' and have seen a number of rigs like the ones you posted. Its a very interesting site with some amazing catches. Our beaches and surf zones are very different, but I have been in contact with some of th guys on this forum to try and take some of the ideas and apply them here.
A big problem is the lack or cost of decent tackle in South Africa, never mind PE! As an example, I would love to move up from 200Lbs steel, but I don't like pianno wire and you just don't find anything commercially available over the 200lbs mark
Still these guys in the States are amazed by what sharks we land using our 'light by comparison' tackle!
Hi Trophy - Yup I saw you on there ..........................
SA certainly does have a different mixed bag compared to the West and East coast in the USA .
Let me know if you need any stuff like a spool of SS cable, thimbles or rattles etc. I will be glad to give it to you no cost no charge . I would be only to pleased to give you this to use and see the difference.
Personally that piano wire is lethal to angler leaderman and shark as it will slice through anything its so thin. If a shark wraps up it will slice it up. I have seen some horrific tragedy's to sharks and people from it. But you have to make do with what you have and a " BOER MAAK N PLAN"
On the west coast we have the big eye threshers sharks Mako, shovel nose, great whites, salmon, hammerheads etc etc Here are some of the species below and some info. Just some info for all.
Alopias superciliosus http://www.elasmo-research.org/education/shark_profiles/a_superciliosus.htm
Big eye thresher shark (Alopias superciliosus),common in deeper offshore waters of the pacific basing including deep waters of Monterey Bay and associated marine canyon
Common Thresher
Common thresher, (Alopias vulpinas) common off California coast and Monterey bay
http://www.pelagic.org/montereybay/pelagic/threshershark.html
[size=+1]
MACKEREL SHARKS[/size]
These sharks are fast, strong swimmers and include the great white shark and the mako. A type of Lamniformes shark, family Lamniformae.
[size=+1]
MAGNETIC FIELD[/size]
The Earth's magnetic field is aligned with the north and south poles, and has reversed many times during geologic history. Sharks may use the magnetic field of the Earth for navigation purposes on migrations.
[size=+1]
MAKO SHARK[/size]
The shortfin mako shark (Isurus oxyrinchus) has a conical snout and long gill slits. It is the fastest swimming fish. These sharks reproduce via
aplacental viviparity (they bear live young but the babies are not nourished via a placenta in the womb; cannibalism often occurs within the womb). Makos can maintain a body temperature higher than that of the surrounding water.Order:
Lamniformes
Porbeagle Shark, Lamna nasus.] The largest-known Salmon Shark was 10 ft (3 m) long. Classification: Order
Lamniformes (mackerel sharks), Family Lamnidae (Mackerel sharks, porbeagles, and white sharks).
estuaries and harbors. Sandbar sharks have a growth rate of about 1.7 inches (43 mm) per year, a slow growth rate for sharks. The thick skin is used for leather. These strong swimmers migrate over 1550 miles (2500 km). Their diet is mostly fish, including menhaden, eels, other sharks, skates, squid, and also crustaceans. Females are mature at 16 years and give birth to 8-12 live young after a gestation period of 9-12 months. Pups are about 8.5 inches (22 cm) long at birth. Classification: Order
Carcharhiniformes, Family Carcharhinidae (requiem sharks).
mackerel sharks (Odontaspididae). They include the
Sandtiger shark (Eugomphodus taurus), the Indian sandtiger (Eugomphodus tricuspidatus), the Smalltooth sandtiger (Odontaspis ferox), and the Bigeye sandtiger (Odontaspis noronhai). They live in tropical and temperate coastlines of all the oceans. They all have long, thin, pointed teeth, and eat mostly fish and invertebrates.
SANDTIGER SHARK[/b][/size]
Sandtigers (
Eugomphodus taurus) are also known as the Ragged tooth shark, the grey nurse shark, the sand shark, and the spotted ragged-tooth shark. They are widespread Mackerel sharks (
Lamniformes) that range from gray to brown and are about 10-12 feet (3-3.7 m) long. They are fish-eaters that have long, sharp teeth in a narrow snout. They eat and migrate in groups; their activity peaks at night. They are found mostly near coastlines, from the surface down to depths of 3,900 ft (1,200 m). are
oviphagous and females have two uterine chambers (wombs). Developing embryos in the wombs are cannibalistic, eating their siblings. Although many embryos are produced, only two are born, one from each uterine chamber. The gestation period is about 8-9 months. Pups are roughly 3.3 feet (1 m) long at birth. Classification: Order
Lamniformes (Mackerel sharks), Family Odontaspididae (Sandtiger sharks).
[size=+1]
SAWSHARKS[/size]
Sawsharks are clade of shark that have a long, toothed snout, no anal fin, and the mouth underneath. These common, harmless sharks have a slightly flattened body, nasal barbels, and its pair of five gill slits are on the side of its head. These sharks reproduce via
aplacental viviparity. Their diet consists mostly of bony fishes. This order of sharks is called the
Pristiophoriformes.
Carcharhiniformes
aplacental viviparity, having litters of up to 52 pups after a gestation period of one year. Pups are about 12-14 inches (30-35 cm) long at birth. Females are mature at 8-10 years and have a low reproductive rate. It is fished for its fins, meat and liver oil.
Galeorhinus galeus was named by Linnaeus in 1758. Classification: Order
Carcharhiniformes (ground sharks), Family Triakidae (houndsharks, topes, whiskery sharks).
Order Squaliformes, Family Squalidae.
[size=+1]
[/size]
[size=+1]
[/size]
Broadnose sevengill,
Notorynchus cepedianus and the Sharpnose sevengill,
Heptranchias perlo) are distinctive and rare sharks that have seven gills (most sharks have five). These unusual sharks also have a single (and small) dorsal fin. The broadnose sevengill grows to be up to 10 ft (3 m) long, is speckled and silvery; this shark has small eyes, and a wide head. The sharpnose sevengill is up to about 4.5 ft (1.4 m) long. These aggressive sharks eat fish (including other sharks, rays, and bony fish), seals, and scavenged prey (including human corpses). Broadnose sevengill sharks live in temperate seas on continental shelves (to a depth of 450 ft (135 m). The upper teeth are jagged and multi-cusped (except the center tooth). The lower teeth are comb-shaped. These sharks bear live young in shallow bays. Litters of up to 80 pups have been found. Pups are about 16-18 inches (40-45 cm) long. Classification:
Order Hexanchiformes, Family Hexanchidae .
[size=+1]
SEXUAL DIMORPHISM[/size]
Sexual dimorphism is the physical differences between the males and females of a species. Female whales are usually larger than the males.
SHARPNOSE SHARK[/b][/size]
The Atlantic Sharpnose Shark (
Rhizoprionodon terraenovae) is a harmless, edible, requiem shark (Family Carcharinidae). The Sharpnose is a small, slender shark with 5 gill slits, two dorsal fins, an anal fin, no fin spines, the mouth behind the eyes, and nictitating eyelids. It has a long, sharp snout, black-edged dorsal and caudal fins (which fade with age), and furrowed or wrinkled corners of the mouth. It is brown to olive-gray colored with white countershading on the belly and is from 2 to 4 feet (60-120 cm) long. A carnivore, it eats small fish,
mollusks, and shrimp. The sharpnose is viviparous, with litters of 4 to 7 pups. Classification: Order
Carcharhiniformes
SHORTFIN MAKO SHARK[/size][/color]
The short-finned mako shark (Isurus oxyrincus), also known as the bonito, is the fastest shark. This fish can also leap out of the water. It has has a conical snout, and long gill slits. Short-finned Makos average 5-8 feet (1.5-2.5 m) long but can reach 12 feet (3.7 m) long, weighing 1,000 pounds (455 kg). The Mako is considered dangerous to people. It reproduces via
aplacental viviparity and the pups are cannibalistic in the womb. Makos can maintain a body temperature higher than that of the surrounding water. Order:
Lamniformes
[size=+1]
SHOVELHEAD SHARK[/size]
Sphyrna tiburo (also known as the bonnethead shark) is a small hammerhead shark with a smooth, rounded head. It has small, sharp teeth in the front of the mouth (for grabbing soft prey) and flat, broad molars in the back (for crushing hard-shelled prey). It is a common, harmless, timid shark averaging about 3.3 feet (1 m) long. It is gray-brown above and lighter on the underside with short pectoral fins Large schools migrate to warm water in the winter and cooler water in the summer. Females are mature at 2.5 feet (75 cm) long and give birth in shallow bays to 8 to 16 pups about 14 inches (35 cm) long. Bonnetheads are found in the western Atlantic and eastern Pacific Oceans, in the surf zone, reefs, on sandy bottoms and in estuaries. Classification: Order
Carcharhiniformes, Family Sphyrnidae (hammerhead sharks).
SHOVELNOSE SHARK (1)[/b][/size]
Carcharhinus leucas is also known as the Bull shark, the Ganges shark, the River shark, the Cub shark, the Zambezi shark, Van Rooyen's shark, the Slipway gray shark, the Square-nose shark, and the Nigaragua shark. It is a large, fierce predator that eats fish, including other sharks, ray, and just about anything else. It has been known to attack people and will venture into fresh water.
[size=+1]
SHOVELNOSE SHARK (2)[/size]
The Dusky Shark (
Carcharhinus obscurus) is a requiem shark that is also known as the shovelnose, the bay shark, the lazy-gray, and the black whaler. It is charcoal colored on top and white with copper-colored markings below. It has a faint pale stripe along its sides. Dusky sharks average about 10 ft (310 cm) long; females are slightly larger than males. The largest one found was about 13 ft (4 m) long. It lives at all levels of the ocean and from the shoreline to out at sea. It is found in warm temperate and tropical waters worldwide. It migrates to cooler waters during warm weather, probably for reproduction and feeding. This shark is often seen following ships and is hunted as a game fish. Overfishing is diminishing the numbers of this shark. Few Dusky shark attacks are documented, but it is considered dangerous. It normally eats small fish (like sardines), large fish (like tuna), flatfish, other sharks, and eels. Females are mature when they are 9 ft (2.8 m) long and have litters of about 10 pups which are roughly 3 ft (95 cm) long each. There is a 16 month gestation period. Classification: Order
Carcharhiniformes, Family Carcharhinidae (requiem sharks), Genus Carcharhinus, Species obscurus.
Carcharhiniformes) that ranges from black to gray on top (and white to cream on the belly). These long, tapered sharks are fast swimmers and are about 10 feet (3 m) long. They have a long, pointed snout. The teeth in the upper jaws are long, triangular, and serrated; the teeth in the lower jaws are only slightly serrated. Silky sharks eat fish, squid, and crabs. It sometimes travels in schools segregated by sex. Females give birth to litters of 6-12 live pups which are 29-31 inches (75-80 cm) long at birth. These sharks are harvested commercially for their meat, liver and fins.
bony fish that is much more closely related to goldfish than to sharks. These common pets are originally from south-east Asia, and may be an endangered species in the wild. These fish grow to about 8 inches (20 cm) long, but is usually smaller. Its native habitat is rivers in Borneo, Sumatra, and Thailand. These "sharks" can be found at most pet stores.
viviparous with a gestation period of about one year. Females usually have 5-6 pups in a litter. Silvertips are attracted to low-frequency sounds. Attacks on people are rare.
Bluntnose sixgill (
Hexanchus griseus), the Bigeye sixgill (
Hexanchus vitulus), and the
frilled shark (
Chlamydoselachus anguineus). These unusual sharks also have a single (and small) dorsal fin near the end of the body. These sharks are gray-brown in color and are paler underneath. The Bluntnose sixgill (also known as the Cow shark, the Grey shark, the mud shark and the Bulldog shark) is a common shark about 16 ft (4.8 m) long with a toxic liver (but edible flesh) and six rows of saw-like teeth in the side of the jaws; it eats large fish, crabs and squid, lives in dark waters at depths down to 5900 ft (1800 m), and has litters of up to 100 pups. The Bigeye sixgill (also known as the lesser sixgill and the calf shark) is about 5.9 ft (1.8 m) long, has large eyes, a slender body, five rows of saw-like teeth in the side of the jaws and lives on or near the bottom of warm temperate and tropical seas. Classification:
Order Hexanchiformes, Family Hexanchidae.
[/b][/size]
SLEEPER SHARK[/b][/size]
Somniosus microcephalus, also known as the Greenland shark, and the gurry shark, lives very deep in the North Atlantic Ocean. It lives at depths down to 1,800 feet (550 m) in very cold water (36-45°F=2-7°C). It is up to 21 feet (6.5 m) long. This grayish-brown shark has a short snout and is a slow swimmer. Bioluminescent (glowing)
copepods attach to the Greenland shark's eyes attract prey to the shark's head! The shark's upper teeth are long and sharp; the lower teeth are flatter, more closely-set (and also sharp). These sharks gather in large numbers in shallow Arctic waters (up to 80° north) during the winter but migrate back to deep waters during the summer. Eskimo hunters traditionally used its skin for boots and its teeth for knives. This large shark is
oviviparous, having litters of about 10 pups, each roughly 15 inches (38 cm) long. Classification: Order
Squaliformes, Family Squalidae (dogfish sharks)
SLIPWAY GRAY SHARK[/b][/size]
Carcharhinus leucas is also known as the Bull shark, the Ganges shark, the River shark, the Cub shark, the Zambezi shark, Van Rooyen's shark, the Shovelnose shark, the Square-nose shark, and the Nigaragua shark. It is a large, fierce predator that eats fish, including other sharks, ray, and just about anything else. It has been known to attack people and will venture into fresh water.
[/b][/size]
SPINED PYGMY SHARK[/b][/size]
Squaliolus laticaudus is one of the smallest sharks; it is roughly 8 to 10 inches (20 to 25 cm) long (females are about 10 inches = 25 cm long; males are up to 9 inches = 23 cm long). This deep water shark has a spine in front of its first dorsal fin but not in front of the second dorsal fin (this is unique among sharks). This harmless shark is very sleek and has a bulbous snout. The upper teeth are narrow and small; the lower teeth and larger and knife-like. It has a large
spiracle (an extra, round gill slit) behind each large eye. It is dark-gray to black with white-tipped fins and bio-luminescence (luminous photophores) on its belly; these photophores light up and may serve as camouflage (they eliminate shadows when seen from below). It eats squid, shrimp, and mid-water fish (especially lanternfishes). This uncommon shark lives in deep water (down to 6,550 ft = 2,000 m) but migrates vertically each day to hunt at night in mid-depth waters (about 650 ft = 200 m). It is found in temperate and tropical oceans worldwide. Its reproductive biology is unknown. Classification:
Order Squaliformes.
SPINY DOGFISH SHARK[/b][/size]
Squalus acanthias is the most common shark. These small sharks congregate in schools and migrate. They are about 3-4 feet (0.9-1.2 m) long and are found worldwide.
Tiger sharks and
angelsharks have spiracles.
digestive tract enables the shark to efficiently digest its food in a small area, since the surface area of the intestines (where nutrient absorption takes place) is very large within the spiral.
SPOTTED SEVENGILL SHARK[/b][/size]
The spotted sevengill shark (
Notorynchus cepedianus) is a distinctive and rare shark that has seven gills (most sharks have five). This unusual shark also has a single (and small) dorsal fin. The broadnose sevengill grows to be up to 10 ft (3 m) long, is speckled and silvery; this shark has small eyes, and a wide head. These aggressive sharks eat fish (including other sharks, rays, and bony fish), seals, and scavenged prey (including human corpses). Broadnose sevengill sharks live in temperate seas on continental shelves (to a depth of 450 ft (135 m). The upper teeth are jagged and multi-cusped (except the center tooth). The lower teeth are comb-shaped. These sharks bear live young in shallow bays. Litters of up to 80 pups have been found. Pups are about 16-18 inches (40-45 cm) long. It was named by Peron in 1807. Classification:
Order Hexanchiformes, Family Hexanchidae. It is also called the ground shark, the cow shark, the broad snout shark and the broadnose sevengill shark.
Order Squaliformes (Dogfish Sharks); Family Squaildae; Genus Squalus; Species asper (the Roughskin spurdog), blainvillei (the Longnose spurdog), melanurus (the Blacktailed spurdog), japonicus (the Japanese spurdog), megalops (the Shortnose spurdog or Spiky Jack), mitsukurii (the Shortspine spurdog), rancureli (the Cyrano spurdog).
[size=+1]
SQUALIFORMES[/size]
A clade of sharks with a short snout, the mouth underneath the snout, and no an anal fin. These include the
dogfish and cookiecutter sharks.
SQUARE-NOSE SHARK[/b][/size]
Carcharhinus leucas is also known as the Bull shark, the Ganges shark, the River shark, the Cub shark, the Zambezi shark, Van Rooyen's shark, the Shovelnose shark, the Slipway gray shark, and the Nigaragua shark. It is a large, fierce predator that eats fish, including other sharks, ray, and just about anything else. It has been known to attack people and will venture into fresh water.
[size=+1]
SQUATINIFORMES[/size]
A clade of sharks with a flat body, the mouth at the front of the head, and no an anal fin. This order include the
angelsharks and monkfish.
[size=+1]
SQUID[/size]
Squid are
mollusks. They are eaten by many sharks and
rays.
rays are closely related to sharks.
[size=+1]
STREAMLINED[/size]
Streamlined means having a contoured shape that minimizes resistance to currents of water (or air). Many sharks have a streamlined shape. This type of shape lets these sharks swim quickly through the water.
[size=+1]
SWELL SHARK[/size]
The Swell shark,
Cephaloscyllium ventriosum, is a harmless, bottom-dwelling shark. It is called the "swell" shark because when it is in danger it can swallow a lot of water, making its body balloon up. This increase in size wedges the shark between rocks, making it difficult to catch. This shark is light brown with dark brown marking; this color scheme camouflages the shark on the rocky sea floor. It is a light brown shark with dark brown spots. Its snout is blunt and it has a very wide mouth. It is nocturnal (is most active at night) and eats small fish. It is oviparous, laying small, greenish, purse-like eggs in rocky crevices. These eggs take 7 to 10 months to hatch, depending on the temperature of the water. Swell sharks are found in temperate waters off the western coast of North America from central California, USA to central Chile.
