Hi Ceaser
Those look good, and I am sure they will work like a charm!
You have inspired me with some ideas! I am also re-producing my own onda look-alike in polyurethane, and I have poured the excess resin into plastic tubes with the idea of making something out of it later.... now I Know what to make out of them.
Just some questions out of interest:
1. Do you use any sort of release agent to get your lures out of the plastic tubes?
2. For those two-tone lures, did you mix pigments into the resin or did you paint the lures?
3.Have you experienced any problems in terms of brittleness of the NCS 215 resin, with lures breaking easily?
Andre
I do not use any release agent in the bottle mould. I just tap it lightly on the side and then pull it out. The two tone lure I use 2k paint. I pour the white first and wait untill it the white just starts to set. When the resin start to set it is like jelly, I then pour the red. I have not fished with these ones, but Im sure that they will not break apart. Bennie knows this resin well. Bennie maybe you can give better information on the strength of the resin.
Â
