Strange bite...off!
aquadementia
How do they generally take the bait? I havent had one eat a bait of mine as of yet . . . Circle hooks should alleviate the bite-off problem
Trophy
HIya Guys,
Here is my ideas on the story...
Small sharky hooked for some time and tried like hell to lift the sinker.
Fisherman eventually strikes and pulls the sinker and small Shark / fish free.
Big shark comes past and spots a easy free meal. Picks up and swallows your small catch.
Manages to cut your steel in process.
Raggies don't make blistering runs and at best 50 - 100 meters slowish run would be an amazing effort from a fighting fit raggie.
My money would be on a GW picking up whatever you had hooked. Esp as you were fishing in our most active GW waters.
spin
1309sg wrote:
aquadementia wrote:
a big raggy could probably bite through 120lb wire especially if kinked it whilst mouthing the bait
220lb may be a bit much though for a rag?
Anyway, was GR* fun, my first real on with a monster, having caught a couple of babes before.
@ Def.. the sea was strong and gettin stringer, I didn't even bother on Saturday. Valentines was a big no-no anyway..LMAO
not a chance i had 220 uncoated bitten clean off by a raggie this sunday. And i can confirm it was a bag as this happened about 4m away from the rocks, plus it surfaced infront of us mid fight.
Trophy
Have to agree with spin as I have seen many Raggies bite through all diameters of steel.
I have also had a Bronzie bite through 200lb steel. All depends where the hook is placed and how the steel jams up against the teeth.
I still think my picture I painted above was most likley what took place??
Katonkel Tom
Hey T, maybe it was a trace bite????LOL
1309sg
Thanks Trophy. Only thing about your scenario was that the gw must have taken that small one a second or two after the first strike.. timing was pretty good! But it makes sense I guess, especially considering that only about 30 cm of the leader was left? = either a big bite or swallowed right into the tummy?
Diamond
Banned
aquadementia wrote:
Whats wrong with Lynx steel wire? I've seen a +/- 90kg sharpnose caught on 160lb lynx red wire and that was after an hour fight with the teeth rubbing the wire
...and I've seen a Cow shark destroy the 90lb, whats your point?...here's mine; The Lynx wire can only be used once then you best cut your hooks out and make a new trace (like once as in you slide it out and when you reel it in you cut it up!!). The Carbon coated steel we normally use can be used repeatedly with no hassles! I have year old traces hanging in my garage from fish I have caught and none of that steel shows any sign of rust or degradation. Lynx wire is not bad for making bundles of sinkers up, thats what I use my roll for!
Def-e-nition
HEy diam, agreed it aint No custard amongst the other makes of steel , but it aint half Bad for it's price . and great for Throw bait traces . Not the greatest of trace wire , but I'd give it a bit More Credit than just for being used to bunch sinkers .!
Diamond
Banned
Stoppie bus........30cm of leader or steel trace left! 30cm of leader...it was a bag! By the looks of your biggest catch you have not landed an in-ed over 100 or even 50kg, what is a blistering run to you (i don't mean to sound sarcastic just want more info)...... Did you hit your braid in a minute/ 2 minutes maybe seconds? i have had a 140kg Bronzie that came all the way in before deciding it didn't feel like hitting the beach and she put me into my braid (300m of topshot) within 2 minutes.......that was a fast run!
Hannes101
maybe the slide never got to the stopper ring. Possible that the GW got wrapped in the leader.
@trophy?
Diamond
Banned
Maybe I was a little over eager on my suggestion but I would not use it!
Just a thought.....R3500 for a rod, R1500 for a reel, R1000 for line and you save R20 on a roll of steel....doesn't make sense?
1309sg
Diamond, my bad, 30cm of steel trace boet, as explained at the start, sorry about the mistake..
And by a run I mean a run so that my line was stripping off faster than anything I've seen, unfortunately until I put more pressure and that was that. And I've seen some serious fish landed by others so don't let my non-ed inexperience fool you.
Def-e-nition
true. Hence- gooi aas . agreed if I'm on My way to Mazeppa then I'm certainly Not Packing in 3 rolls of Lynx to haul Out in front of Trophy , he Might Laugh at us too Much .. ..
I Use the Lynx goodies for Hammers and small bronzies, duckbills ,  Lerger nunu's I've found Robyosh Use of bicycle cable   to Be Most effective ....
Diamond
Banned
I'm back to my original post, take a lesson from the lost fish and put the next b!tch on the beach!!!......no post mortems!!!
Whaler
Hannes101 wrote:
Same thing happened to me at kleinbrak just a few k's down the beach. Had a pick up, set the hooks, line start to strip with lighting speed and bam a GW breached and bit my 200lbs carbon coated slide stace of. I can guarantee you it was a GW. It got pick up 4 times over december holidays by those sharpnose bronzies. Their definitly becoming a nuisance... in that area. Best advice for the okes sliding in that area are to use BARBLESS hooks..
or 400lb steel!LOL defenitly a white! there is no doubt, they have been prolific in that area the last few weeks! as for Aqua's theory, these whites can lie in one place for 10minutes easy, as long as there is current the water will flow over the gills, when the water is clean you can see them idling on the backline using the swell to forse water over them, another myth is that they become sexualy mature at 4 meters! rubish! i have seen a 2meter very pregnant female...they evolve with us or maby faster, who nows...
roland
nooooo, now you tell me, and that after i landed 3 (ok, smallish) rags on one linx trace? yoh. best i go make some sinkers with it hey ::S
spin
Bit of info use it dont use it, this is were i am at the moment with my evolution in shark fishing. For competetive fishing all my throw bait traces have about 40cm 220lb uncoated wire and then about 60cm 200lb bite back. For outings to mazeppa or other deep water spots all slides are 440lb uncoated steel. At home its a mix up of 200lb to 250lb carbon coated or uncoated. I am also trying afi's 218lb tooth proof wire for the bite section on throw bait traces.
