Strange bite...off!
1309sg
Went to Mosselbay on Thursday and decided to wet a line near Grootbrak, place called die Vette Mossel. Now, I don't slide often and am no pro in that regard, so it was quite a mission to get the whole mackerel in on incoming tide.
Finally I was happy that the slide was at the stop ring and settled to wait. The following was a very strange experience: A very slow pressure was put on the line by something or other, my drag set on about 50%, clicking out my ratchet every 3 or 4 seconds. This went on for about 10 minutes and I decided to 'maak vas'. Good grief, whatever it was took line at a rate of knots, probably 30 seconds and then I felt something like the hook pulling......
Brought the sinker in and there to my utter amazement, my slide, with 30 cm left of the original 1,2m 220 pound nylon coated wire trace. Snipped through as clean as you like???????
Can someone explain what happened here. Locals said a GW, but why then the very slow initial bite?
Def-e-nition
G White .
No doubt about it .The Tend to "flip the bait" over , like a dog rolling a bone in their Mouths , and once "consumed by the beast "(!) it takes off ...........
Obviously on the first Take youwere taken , then it bit you off .
Nice - I wished So badly i could join you the Weekend . ... Ran My Gat off . and voelklip - yoh- Niks ....................................
mnyamane
Give carbon coated wire a try next time
1309sg
aquadementia wrote:
a big raggy could probably bite through 120lb wire especially if kinked it whilst mouthing the bait
220lb may be a bit much though for a rag?
Anyway, was GR* fun, my first real on with a monster, having caught a couple of babes before.
@ Def.. the sea was strong and gettin stringer, I didn't even bother on Saturday. Valentines was a big no-no anyway..LMAO
1309sg
What's the diffs between carbon coated and nylon coated? Most of the trace illustrations say either or would do, but I used nylon because of the neater knots?
Def-e-nition
um- Ja I Know what you Mean about 14th .
 Wife Nevertheless Let Me go . What an amazing look on my face when she said it was fine - priceless .
I'm sorry i didn't join you .
My sliding from the beach as described several times on this site , rivals something of a cross between a Beached whale trying to do reverse Gear and something from america's funniest home videos .....not for the faint-hearted , i assure you .
And lately - Wierd- Nunu's are being hooked in-shore a lot more frequently than my Mazeppa-style off the bricks Kek .
which Leaves me where then , exactly ?- Ja .
Flippin cool...!
You Lucky to have had a pick-up .Expensive if you are Caught , but Much like all things - we are assuming here , and - assumption is the Mother , as the saying goes .....
Even huisie (bankies ) Has Not been Producing .
 I took Mango saturday to Saal - Yip - nog N Blank pappa .
Looks so good whan you Take These P.e Okes Who are spolit ROTTEN fishing from the Pier ( !! ) to a Nice spot with plenty possibilites- en niks kom groet nie ....... Ja  Wat .
you Must Pm Me your Cell No .
deezynking
im no expert just my opinion,
you say after 10mins you struck him and he went off like a bullet. could have been any big shark, and with bitting on the bait for ten mins or so could have kinkeked te trace several places and as you fought him, it gave way. but 220 lbs ... thats a big dude. i would assume GW for sure. but one can only assume.
at least you had your few secs of glory, unlike me didnt do no fishing
mnyamane
It happens at times that when a big shark swallows bait nylon coated wire gets stuck between its teeth and when it jets off the wire gets cut. The nylon which covers the wire is plastic-like, this is not the case with carbon coated wire.
My fife bob...
aquadementia
Sharpnose bronzies being very much non-demersal, wouldnt sitting on the bait for ten minutes drown it? It breathes by making use of ram ventilation (its gotta move to breathe), unlike raggies, flatfish and the like that can force water over their gills. Something to perhaps consider when trying to ID the fish?
Diamond
Banned
The colour!! ROFL!!! Honestly I don't know.
The Raggies can sometimes bite the thicker steel easier than the thinner stuff. reason; the thinner steel can often settle between the teeth, that is the theory as explained to me by an experienced angler. The slow pull....i dunno! Does it really matter, take your lesson and put the next one on the beach!
P.S. what brand of steel were you using....wasn't that Lynx stuff was it?
1309sg
@ Aqua: that's what's been bothering me about the whole episode. Surely a shark would pull it faster than the slow death click I described? Anyway, I suppose I'll never know.
In a case of a shark 'mouthing the bait' you would obviously wait until it takes off before setting the hook? As a general rule that is? Or would you have done the same as I did?
1309sg
LOL..no Diamond, I think it was a Kingfisher product, and there was nothing wrong with the steel, I checked that out beforehand, especially to test my newbie knots. Copied from Trophy's rigs, including all the bling... looked good enough to eat!
J
Is it not possible that shark was big enough to be cruising around slowly for 10 minutes oblivious to the fact that it was hooked?
Hannes101
Same thing happened to me at kleinbrak just a few k's down the beach. Had a pick up, set the hooks, line start to strip with lighting speed and bam a GW breached and bit my 200lbs carbon coated slide stace of. I can guarantee you it was a GW. It got pick up 4 times over december holidays by those sharpnose bronzies. Their definitly becoming a nuisance... in that area. Best advice for the okes sliding in that area are to use BARBLESS hooks..
aquadementia
Whats wrong with Lynx steel wire? I've seen a +/- 90kg sharpnose caught on 160lb lynx red wire and that was after an hour fight with the teeth rubbing the wire
