Hiya
Most of the anglers i fish with all use 24kg line, straight. No leader, no double lines, just clear or light green coloured 24kg line.
Why 24kg's? Well, it's alot thicker and thus stronger than the thinner diameters. When the 'tail are in shallow water or close to the kelp beds, good luck with the lighter lines!!
I've lost PLENTY of fish, even on 24kg line, when they make a run for the kelp, especially in the shallow waters.
I don't bother using flourocarbon for 'tail. Using it WILL be better though. I just like to keep things simple. No knots to interfere with my casting, so knots to whack my fingers!!
The reality is that you don't even need to use a bimini twist. Since a snake spinner is VERY light, even tied directly to 10kg line, you will not be able to snap it off. A few seasons back i took a 40kg YF on a 7' Beastmaster and a TSM3 shimano, with 10kg line, no leader, just a snake tied to the end, at Bellows.
Remember, you're fishing off a boat, so casting is never a problem. The skipper must always try and ensure that the anglers onboard will cast WITH the wind. If you're a proficient caster and there are plenty of boats around, and casting INTO the wind is the only option, then having as few knots in your line is best.
Many of the experience yellowtail guys also LOVE the shimano exage 11'. The longer rod will give you extra distance, which really helps when the schools are very spooky.
miles
