spinning reel??
mikesfb
looking for a spinning reel to pair with a 10 to 12 foot rod for throwing plugs and poppers for kob...
what do you guys think about a daiwa bg60?
Echo7
Not the most sophisticated... but strong and reliable. Mine is almost 7 years old and still going strong, also its not badly priced.
docside
Great reel, very strong! I have one for some years now. Only downside is that is a bit big, and heavy! How about a BG30? not sure how much line you can get on that, though.
Overall, good value for money!
Echo7
For Kob, enough I would imagine. Try those X Rap Slashbaits..slow retrieve, neilg might be able to shed some light...
steve m
shimano spheros 8000 or even a 12000 fill it with 20lb-30lb braid for cob
here is the specs on the spheros
Model: 12000FA
Gear Ratio: 4.6:1
Line capacity: 265yd/20lb, 350yd/16lb
Max Drag: 20.0lb
Weight: 28.4
Features
  • Stopperless Design [/*]
  • Aluminum Frame [/*]
  • Graphite Sideplate [/*]
  • Graphite Rotor (Aluminum on 14000 & 18000 sizes) [/*]
  • Power Roller III Line Roller [/*]
  • S-Arm Cam [/*]
  • Aerowave Oscillation (3000 & 8000 sizes only) [/*]
  • Aero wrap Oscillation (14000 & 18000 sizes only) [/*]
  • 3 + 1 Bearings (4 + 1 on 14000 & 18000 sizes only) [/*]
  • Super Stopper II Anti-Reverse [/*]
  • Direct Drive Mechanism [/*]
  • Dyna-Balance [/*]
  • Fluidrive II [/*]
  • Cold Forged Aluminum Spool [/*]
  • Waterproof Drag [/*]
  • Easy Access Drag Washers [/*]
  • Dartainium Drag (6000 - 18000 sizes only) [/*]
  • Rubber Handle Grips [/*]
  • Repairable Clicker [/*]
  • Optional Kit available for No Bail Wire configuration on 5000, 6000 & 8000 sizes. Part number: SWBAILKIT58 [/*]
  • Optional Kit available for No Bail Wire configuration on 14000 & 18000 sizes. Part Number: SWBAILKIT) [/*]
  • Approved for use in Saltwater
model: 8000FA
Gear Ratio: 4.7:1
Line capacity: 160yd/20lb, 220yd/16lb
Max Drag: 20.0lb
Weight: 19.8
Features
  • S-Arm Cam [/*]
  • Dyna-Balance [/*]
  • Fluidrive II [/*]
  • Approved for use in Saltwater [/*]
royboy
Yes the Spheros - Linda's 8K FA is such as sweet reel!!!! Tough little buggers as well, she has caught good fish on it. Lots of good fish including a "sort of respectable" GT at Bazaruto. Loaded with 30lb Tuffline XP (I think 50lb - bright yellow braid)
No comparison to the top-end reels (I love my Stella 10K) but that little Spheros? I can't say enough good things about it!
I seem to recall someone telling me that this was one of the 1st Shimano spinning reels designed exclusively for Saltwater use, (probably heresay - but heck, it has performed so beautifully over the last 2 years, I would like to believe it's true).
Guys like Neilg will support this as well - excellent reel at the price-point! Google it, you won't see many complaints anywhere in the world!
aquadementia
A size 8000 loaded with braid should do the business. Iv got a 6000FA, which is pretty much the same and its a great reel! Its got a similar max drag rating as a Torium 30, so the answer is YES it can handle a decent sized tail. If the tail are scarce then you can throw baits for little hammerheads etc
