Hiya
The 3 species you've mentioned looking at, are VASTLY different to one another, so completely different lures will be needed.
Skippies/Katonkels
These are rather small fish, seldom exceeding 3-4kg's. ANY small spoon will work. Abu Toby style spoons and Halco Twisty's are my favourites. Small chisel nose plugs are also very effective. Use 1-2oz sized plugs. The top water strikes are IMPRESSIVE!! Rigged on a 7' rod with a 2500 sized reel and 10-15lb braid and you'll have PLENTY of fun with these fiesty little buggers!!
Caught accidentally whilst targetting yellowtail
Longfin/Albacore
They generally average 8-20kg's with 20-30kg fish being quite common. They require larger lures are heavier tackle. My favourite set-up being a 6' Shimano Beastmaster 85-200gram jigging rod matched with a 6000/8000 sized spinning reel with 50lb braid. Longies are not fussy when it comes to spoons!! ANYTHING will be taken when they're 'dik'. My favourite is the BRINIC, developed by the LEGENDARY SPRINGBOK anglers, the late Brian Hart and Nick de Kock. Next best is the Ashley Read round back and the venerable snoek killer, the Ashley Read GARFISH. These HEAVY spoons sink quickly, allowing you to cover a larger area of the water column. Chisel-nose plugs also work and offer exciting top water action, but they're at their most effective when the fish is 'dik'. Spoons FAR outfish them!!
Flippy with a 20kg longie with the Ashley Read Round Back still in its mouth
Wifey with a 29kg longie on a BRINIC, that won the ladies prize at the Gordons Bay Offshore Classic
The Fight:
wiifey with yet another 29kg longie
Longie spoons marked with a red box:
Chiselnose plugs, cheap and DEADLY!!
Yellowfin
In many countries across the world, YF's are SUCCESFULLY targetted on jig's, top water lures and spoons/spinners. For some strange reason, VERY FEW are landed in our Cape waters on these methods. I've caught less than 10 YF in the deep, on spoons, meant for longfins, in my fishing career!! They are simply not interested in the spoons. The only reason which makes sense is that these YF in the deep are SCAVENGING behind trawlers and longliners and thus are not in tune to chasing baitfish like they do normally. Why waste energy chasing baitfish when the chum from these vessels simply drift around.....
How-ever, when the warm water comes close to Cape Point and the YF do come close in, THEN they are forced to feed on baitfish. Here i have caught MANY YF's, from the smallerl 10-20kg YF's right up to 70kg+ YF's on spoons and plugs meant for yellowtail.
For YF, rather stick to trolling or BAIT fishing. FAR more effective!! When the day does arrive that they are close inshore, 2-4oz chisel nose plugs offer EXPLOSIVE top water takes!! Snake spinners, Garfish's, Roundbacks, etc have all taken YF, so when you DO get them in that feeding mood, use any spinner that you like.......
