Spinning for Tuna
Ledge
Hi guys,
I was recently out in the deep and there were loads of longfin & Skipjack tuna feeding. I was just looking for some advice regarding what lures to use? Specifically for Skippies, Longies and ultimately yellow's.
Thanks,
L
SPIN A HOLIC
Hey ledge. Tuna are not always that fussy so most time you can get them to eat anything.
Do you also chum them and follow the trawlers or do you guys just troll.
If you guys troll I would keep a rod rigged up with a 3 to 4oz plug so once you get a strike and the other guys are fighting fish then you can throw some plugs or spoons on the surface.
Alternatively you can jig with jigging spoons but its hard work and not as fun as seeing a 100lbs yellowfin cane a plug.
If you chum and bait fish for them then I would throw 7inch Mcarthys with a 3oz lead head and a 9/0 hook in it. Often I go upto 12/0 hooks.
When the fish come around the boat just flick it out and tweek it around the water column. Shouldn't take too loing for the first hook up.
Fin-S
I have found that skipjack take much smaller lures when spinning than when trolling. I use a heavy 7cm storm or a small toby. They can be quite fussy though. Last time out, we had more success on a fly than on a spinner.
For longfin, you really want to cast at the shoal as one of the fish takes on the troll. The idea is to bring the rest of the shoal into range of the baits. Hence something you can cast a fair way, that sinks quickly and that you retrieve fast. My go to lure is the Ashley Read keel spinner.
For yellowfin, trust me, the last thing you want is a 60kg plus yellowfin inhale a spinner on a long stick. If they are small fish on the surface then just match what they are feeding on. I am now using an Exage GT rod with a Stella 10k, rigged with a big Halco Rooster - it is OK up to about 35kgs. Over that, then you get into really specialised and expensive tackle if you want to land a fish and still walk afterwards!
miles
Hiya
The 3 species you've mentioned looking at, are VASTLY different to one another, so completely different lures will be needed.
Skippies/Katonkels
These are rather small fish, seldom exceeding 3-4kg's. ANY small spoon will work. Abu Toby style spoons and Halco Twisty's are my favourites. Small chisel nose plugs are also very effective. Use 1-2oz sized plugs. The top water strikes are IMPRESSIVE!! Rigged on a 7' rod with a 2500 sized reel and 10-15lb braid and you'll have PLENTY of fun with these fiesty little buggers!!
Caught accidentally whilst targetting yellowtail
Longfin/Albacore
They generally average 8-20kg's with 20-30kg fish being quite common. They require larger lures are heavier tackle. My favourite set-up being a 6' Shimano Beastmaster 85-200gram jigging rod matched with a 6000/8000 sized spinning reel with 50lb braid. Longies are not fussy when it comes to spoons!! ANYTHING will be taken when they're 'dik'. My favourite is the BRINIC, developed by the LEGENDARY SPRINGBOK anglers, the late Brian Hart and Nick de Kock. Next best is the Ashley Read round back and the venerable snoek killer, the Ashley Read GARFISH. These HEAVY spoons sink quickly, allowing you to cover a larger area of the water column. Chisel-nose plugs also work and offer exciting top water action, but they're at their most effective when the fish is 'dik'. Spoons FAR outfish them!!
Flippy with a 20kg longie with the Ashley Read Round Back still in its mouth
Wifey with a 29kg longie on a BRINIC, that won the ladies prize at the Gordons Bay Offshore Classic
The Fight:
wiifey with yet another 29kg longie
Longie spoons marked with a red box:
Chiselnose plugs, cheap and DEADLY!!
Yellowfin
In many countries across the world, YF's are SUCCESFULLY targetted on jig's, top water lures and spoons/spinners. For some strange reason, VERY FEW are landed in our Cape waters on these methods. I've caught less than 10 YF in the deep, on spoons, meant for longfins, in my fishing career!! They are simply not interested in the spoons. The only reason which makes sense is that these YF in the deep are SCAVENGING behind trawlers and longliners and thus are not in tune to chasing baitfish like they do normally. Why waste energy chasing baitfish when the chum from these vessels simply drift around.....
How-ever, when the warm water comes close to Cape Point and the YF do come close in, THEN they are forced to feed on baitfish. Here i have caught MANY YF's, from the smallerl 10-20kg YF's right up to 70kg+ YF's on spoons and plugs meant for yellowtail.
For YF, rather stick to trolling or BAIT fishing. FAR more effective!! When the day does arrive that they are close inshore, 2-4oz chisel nose plugs offer EXPLOSIVE top water takes!! Snake spinners, Garfish's, Roundbacks, etc have all taken YF, so when you DO get them in that feeding mood, use any spinner that you like.......
fedu
Miles,
I should have seen you post before I ordered my "offshore" spoons, now I'll have to buy some more... :)
Very intresting that YFT on the deep feeding reasoning, makes sense the "match the hatch" there is chum line..
On another note to the OP Tackle Whore as had some "casting encounters" with the fussy YFT in the deep and on another sealine thread writes:
"yellows love stickbaits orion tropic 150 and wahoo 100 blue/green mackrel work in the canyon as well as flapper 130 . if you hear screams at 35 05 its me getting smoked ."
http://www.sealine.co.za/view_topic.php?id=56571&forum_id=67&page=2
kraken
Coupla weeks back, the longfin were climbing onto this plug. I lost count of how many nailed this cheap piece of plastic. Throw, hit water and one or two turns and VAS!
When longfin eat, they EAT! When poling on the big deckboats, the water literally turns black with packed longfin and you literally just dip your cavalla in the water and they jump on. They become suicidal!
I've had much success with the same patterns Miles mentions, but made by Steve Champion.
My fishing buddy nailed a beaut 50kg yellowfin on a Roosta popper during our longfin party and lost a considerably larger one with the next throw.
Personally, I reckon there's heaps of potential out there for more catches on artificials.
Have seen yfin take cavalla at times, but usually ends up with broken poles......
Ledge
WOW! Thanks guys for your awesome input!
Most of the tuna I have caught have been while trolling.
I am used to spinning for Yellowtail, but from what I am hearing, the "rules" of spinning for tuna are similar, but nothing like it... The right presentation at the right time!
Miles, Thanks for the images, VERY Helpful. I'll keep at it!
I'll let you know how it goes when I go again. Hopefully this week. The swell is not nearly as big as they predicted, and the water temp is rising to the west.
Cheers,
L
JJ Pienaar
Dont knw about longfin and skipie's but here in Durban we use Halco Rooster poper's for yellowfin . . .work's like a charm
landshark
This baby picked them up whilst trolling and spinning.
During our last trip to Struis the Skippies could not leave the lure below alone.
It out-fished all the other lures we tried (and we tried a few...)
Ledge
Hi Guys,
We were out yesterday and I picked this one up on some lighter tackle spinning... The Trustee Tin Garfish...
Got my first hit +- 10-15m in front of me. Very aggressive strike that knocked the spinner clear out the water! Fish broke the surface and ... no Hook-up! Cast again, let it sink (trying not to get too excited), retrieved and had the exact same response in almost the exact spot as the previous retrieve. This time...Vas! Quite some time later (maybe 35-45 mins) the fish was in the boat... What a fight. A few grams under 25kg.
Thanks guys for all your valuable input!
Keep it coming. I'm keen to learn and I'll let you know how I get on.
Cheers,
L
BTTB
Awesome fish Ledge.
Now that you are hooked to fishing off the boat are we still going to see you from time to time on the other ledge. :p
Ledge
Hey BTTB,
Thanks for that. The chase of the Yellowtail is still awesome. I think you'll see me at our favourite ledge soon. I hope the water warms up a little bit more and there are a few misguided yellowtail about. I know the season is pretty much finished in the bay, but there's always hope.
On another note, when we were running back there was a MASSIVE piece of kelp about 8 miles out with lots of sterretjies circling in 17 degree water... All the signs were there for some yellowtail action. We never stopped to give it a go though.
I hope to see you soon.
Cheers,
L
BTTB
The conditions should be good over the next few days for a Tuna trip Ledge.
I can remember back to my earlier days fishing 20 to 30 miles off Hout Bay during May in calm conditions with patches of mist in places, usually inshore.
Pity you never stopped at that weed, almost guaranteed to find pockets of Yellowtail under them.
brandonz
Ledge wrote:
Hi guys,
New Halco Skim Stick is working like a charm. Nice tuna, Couta and Dorado coming out on them at the moment.
