Spinning for gulley sharks...
Riaan_The_Legend
Hey guy's.
A slightly technical question today. At the end of the month I am going to invest in a new setup. It's main purpose is going to be for throwing artificials (Around 1-2 ounce bucktails and jerkshad type lures) for gulley and hound sharks, mostly in the Strand area.
I have looked at a couple of options and I am torn. On the the heavier side I am looking at the 6000 Sustain paired with a 8ft Exage. This setup is so solid, but it's going to lack versatility because it falls on the heavier side of life. I would probably load it with 40 or 50lb PowerPro braid. The only other application I may have for this is spinning for Yellowtail at Rooikrans? Would it be suitable for that?
The next option is substantially lighter and I'm not sure if its heavy enough. A 4000 Saragosa on a Daiwa XH 9ft with 30lb PowerPro. This setup I could also use for other artificial applications around Cape Town. Hence my dilemma. Should I go heavy and safe of light and versatile. Ultimately I know it come's down to personal preference, but I'm hoping someone with more experience could give me some advice...
Oh, adding to this I have a 5600 Abu C4 paired with 40lb braid and a 8ft Heavy Crucial which may make the lighter option redundant?
Thanks a lot, Riaan
Riaan.
I have done my share of spinning ,but have never targeted gulleys or hounds on spinning,how ever i know these spesies and have caught loads of them.
I think youre tackle setup with the exage is fair ,but do not know the ratio on youre Abu?
the thing is keeping a gulley away from the rocks is going to be a problem with light tackle .
houndds on the other hand will take off like a bullet and are clean fighters relying on there speed and stamina .
but please keep me posted on this and let me know how you fair.
Riaan_The_Legend
Thank you. I know these fish are as dirty as they come but form what I understand, the target size of the fish will range from 10kg's all the way up to 25kg at the biggest, so perhaps the lighter setup will do. The Abu is more of a backup rod for now. I hear the Exage may be a little stiff for throwing smaller lures so perhaps I may have to go for the lighter setup. Flip, what a catch 22.
Marthin
Riaan i've got very little experience or knowledge.
But if you are targetting critters on the reefs in strand you will probably have to turn them quick, so i'd go for more backbone.
Riaan.
10 to 25 kg fish sorry boet youre light tackle isnt going to work not with gulleys,we really have to hit and hold with our big tackle to keep them from the rocks.
there is a allternative ,try and target these fish only in gulleys and drop off areas where there is less rocks ,that gives them no chance off eventually cutting you off.
GOOD LUCK
Riaan_The_Legend
I intend on fishing the Strand area as mentioned above and there are stacks of reefs to chop me off, perhaps the Exage will be the better option. I know there are a few guy's who are consistently landing them on 15wt fly rods so I know it can be done. I'm starting to think I might get owned with the lighter stuff.
aquadementia
Howsit Riaan. Iv got an ugly stick 9ft xxh, it has a lot of backbone, more than the Berkley air i think. Its rated to 40lb line. I use my Sustain 5000 and 14lb fireline with it. It can throw up to a 3ounce weight but 2 ounce is more comfortable. Theyre also relatively cheap. Its got a graphite core thats glass covered, making it very strong and bump resistant. The blank has got a ten year warranty. Maybe check it out?
KLIPVIS
Riaan I think you might have problems inticing the hounds to take your lure , have anybody on this site caught any hounds on fly before ? To get them in feeding mode you will have to chum and that could get interresting and actuall FLIPPEN terrying out on the reefs with some large bronsies and raggies coming in for a meal.I suggest you try and land a hound of the reefs with your normal R&S tackle and then decide what outfit you need.Boet those spotties tow you around on the reefs or cut you off very quickly even using stroke7 rods and big reels.You will be a legend if you land a 20kg spotties on light tackle.Good luck
Hooked
Not on this site but there are guys who tackle them with 12 weight fly rods
Riaan_The_Legend
I dont know of anyone on this site, but I do know 2 gents who do it quite regularly and I have had them eat a jerkshad more than once, so I'm sure it can be done. But thank you for your response, the more I hear about these fellows, the more I think I should rather buy a R&S setup and go bully them with that? Maybe a 11ft Exage and a Torium. That would also be great because I can use it to catch other eds with as well?
steve m
http://globalflyfisher.com/fishbetter/sharks/
check this out if they can get on fly im sure you can get on lure
G
Guest
Guest
Hello Riaan
I think that you are onto something. To me this would be pushing artlure angling to its limits and that is what excites many folks about angling. My vote would be for the Sustain/Saragosa 6000 and a rod to match. Speak to Nepps. He will have some funky rod ideas for you. I have a 7 ft light Shimano Trevala spinning rod. It matches well with 4000 Sustain. Not expensive rods. Saw them at Suburban spares the other day for R 565. Maybe look for a stronger model of that. i would also use Fireline over some of the other braids, purely for its abrasion resistance. We use 80lbs Fireline as leader when targeting fish that fight dirty like yellowtail and GT's. The more that you try this, the more that you will tailor every bit of your tackle to iron out all of the weak links.
Great post. Keep us all in the loop. You will defintiely be pushing the boundaries.
Anton
Riaan.
Here is an Idea.
I took a 400/3 marlin blank, wich is relatively soft comparing it to a 400/3 purglass,actually very soft ,I chopped of a 30cm tip then cut it down and build a short rod with lots of backbone ,with a short butt end as i dont use a rodbucket when spinning the total lenght is 2.5 meters ,but casts anything from 2 ounce to 5 ounce ,and i can pull a stuck Oshkosh out a mud hole with it.
I put 8 guides to help with the stiffnes as well as any flat spots i tend to bend this rod a bit and really pull hard on it.
Think about it maybe we can try and get the rod down to you ,to use and try.
regards and good luck
aquadementia
my dad with a hound caught bouncing some or other Gulp Chartreuse Jerk Shad thing on the sand between 2 reefs. This was just a once off, but if you can figure them out please let us know!
DJP
Waiting for October to start targeting the gullies. There are spots that you can catch them from the beach. Right time and right place. If you have enough line (+400m) you will be able to land them on light tackle.
Never mind the kob...check the two red circles...gullies feeding in very shallow water. Getting them to take the bait...now thats another story...
DJP
Sory, the top pic's quality isn't that good. Just to prove that those were gullies. Riaan pm me closer to oktober and we can make a mision if you'd like.
Riaan_The_Legend
I thought about it today and I think I'm going to go for the 8000 Saragosa and a 10ft Exage. That just means that the setup will be far more versatile etc. I'm not keen to spend a small fortune and then only be able to use it in one place. DJP, that would be amazing. Should have the setup ready by then. STOKED.....
Riaan_The_Legend
Haha, small spanner in the works, but perhaps it was a good thing. Couldn't get to the shop because I had to work later than expected, but did some thinking and perhaps this isn't the route I should take for the moment. I don't have the world of oney and I have wanted to get a R&S setup for quite some time. My concern is that the 10ft Exage is too heavy to throw small jerkshads and the 8ft is very limited in it's application. Hence i am going to get the 11 ft Exage and a 16 or 20 size Torium for now, just to get the feet wet in terms of rock and surf and perhaps later in the season I'll look at another setup? Thank you so much for all the advice untill now and bear in mind that it's not in vain, the timing is just slightly out... Otherwise, I will let you gent's know how the R&S stuff goes.
