fstf roller
.....and man not a regret around even though this product is an expensive one!
Have a look below
I got the blue one in 7ft, this package comes with everything you need, very detailed instructions and a disc with a 7 min instructional wich you can also fine on youtube.
The most difficult part about fitting this product is the measuring/taping down and the physical part of sticking it to your boat, the other preperation parts were very basic.
After the measuring and taping, it's time to etch the boat as they say, i made sure i went about 5mm over the edge of the guard so that the edges of the guard stick properly.
I was a bit concerned that the 320grin etcher might damage the boat but it roughens up the surfaces very slightly it's to give it a secure fit.
The only thing not included is something to clean the etched surface with, i used acetone that i got from builders, was like 20 bucks or something.
After that you prime it with the primer included
After thats it's time to stick it on, this took the most hands as you need it to be center and pressed quite hard.
This gives your(or my boat at least) a real cool look and obviously protects the keel, it also has a lifetime garentee according to the packet and it's quite heavy duty!
If you guys are intressted in getting some of these, get at me then i will send prices, they are available in lots of different colors and lengths!
I took a pic of the complete product but cant find it, when i do i'll post!
Have a look below
