mighael.vs
Hi guys
I want to start targeting ineds, but by current beach setup up is a bit light for those big ones.
I have a rod that will work and a heavy reel normally used for deepsea tuna fishing. So I am trying to figure out a way which I can use the setup, as trying to cats will most probably end in disaster and hours of trying to untangle the inevitable kraaines. I thought about using a kite to fly the bait out, but this will be dependant om the wind direction, which is normallly not favorable in the mosselbay area from my experience.
So here's the plan...
Would it by possible to use my current setup to throw a sinker, then use the heavier rod and reel to attach the bait to, and slide it over the line of the lighter setup? By using a light leader on the sinker trace, it should in theory by able to easily break off when the bait gets taken? Then one can fight the fish directly on the hesvier setup? I was thinking of attaching a power swivel on the opposite side of a non-return slide? Any opinions on if this method will work? Or am I chasing a ludicrous idea? Any other suggestions?
