[size=3][font=Calibri]What you need,[/font][/size]
boepens
Make my own too
I've been experimenting with that bend closer to the coils and I find
That the slide progresses quicker through the water
With weights it has less chance of wrapping too
@ dirk how hard is the tig wire compared too spring wire ?
:::S:::S
boepens
Pic of my slide trace ,make my slides almost the same way dirk does
DJP
dewalds wrote:
Awesome stuff!!!
Sorry for the stupid question, but what is the function of the heatshrink?
The heatshrink is supposed to go over the wrapping coils where the swivel is connected, there is a tag end and some people fear that the line might somehow be damaged by this.  See post 32, by Patrick C.
DJP
boepens wrote:
Make my own too
:::S:::S
I have only worked with 1.3mm spring wire, so cant compare it to the tig rods, but the rods are plenty strong. I have made about 20 slides this weekend for out trip to Kei, another 20 tonight, and I'm sorted, leaving on Thursday.
FLUKE
Here is one of the slides I make next to an 18/0 Eagle Claw circle
Here is one on a trace with a 20/0 Eagle Claw
@ Boepens, the Tig Wire is a bit softer than the spring wire and also doesn't spring open after you bend it.
I'm certain the S/S Spring wire is stronger but it would not work as per this method shared by DJP. Hitting a chisel in would not open the coils because as soon as you took the chisel out it would close again.
FLUKE
boepens wrote:
@ fluke I need to get some that s/s wire
There's a place in JHB I get it. I buy 100mtr at a time and use it for sinkers and everything because the S/S spring wire from Jhb is cheaper than the normal spring wire in EL.
I still have quite a bit but the next time I order I'll give you a shout.
johand
To make things easy to get the  twist/coil wrap the ss wire or tig wire around a couch screw,nice even space no hitting with a chisel saves time.....works for me.
BigBen
Brilliant...This post gets better.
Now to find a small cheap bench vice on the fleaMarket this Sunday.LoL
timwalden
Hi folks! I'm just about to start making some slides for a trip to Florida in May. However, I have looked at the options for the ring above the lead, and the split ring's ive seen don't look up to the job. Can anyone advise what they use?
Thanks,
Tim
makka7
Great thread!
I have been using ball sinkers instead of the beads, no chance of them crushing under the pressure!
Dave Batista
Here's a picture of my slides that I've just made. Just need to hook a groot non-ed to give one a test.
