dalkill wrote:
OK, that gives me some direction as to bearings.
For a service, when you paln to regrease / re-oil, do you wipe clean the components, like the gears and rachet of the old grease and then put on new grease, or simply add to the existing grease
Once you've taken everything apart... dump it into a plastic container with Benzene (really cheap stuff) leave it for an hour and you'll be absolutely amazed at how clean your parts are. I dump the bearings, drag washers in as well, but the felt or leather ones, I just soak for about 10 minutes.
Take them out, place them on some Carlton roll so that they dry out well, then start regreasing... I grease my drag washers as well with a very light coat of Teflon grease.
Bearings get done with Mobil one/ Prolong/Drug addict method::H... put all together again Vooopah, at least a 2minute freespool spin!
If your reel gets used a lot, I was freaked out as to how SIFF the grease inside the reel gets if mixed with water.... Never again!
