Sand Anchors
Riymos
Banned
Hellos
i used to by these graps from basil manning they are verry similar to normal graps only thing is the wire is alot thicker and also the main shaft on the grap is twice the length of the normal grap. {Sand Anchors}
does anyone know ho else besides basil manning may have them because they are always out of stock and dont have all the different weights.they seem to only keep 9 and 10 ounce.i need to find some 7 and 8 ounce asap.
a wholesaler would be great thanks guys.
Khani
Hi Riymos,
I picked up a couple of thick wire  8 oz graps from fishermans warehouse on Saturday and they seemed to have sufficient stock.
Khani
Riymos
Banned
 howzit khani
tell me those graps do they have the longer shaft approx 10 cm long
those are the ones im looking for
cheers riymos
Khani
Hey Reymos,
Now I know which ones you are talking about, Those I have only seen at Basil Maning's and no where else.
In fact I have 2 of those in 8 oz, If you dont manage to get any 8 oz you're welcome to the 2 that I have.
Riymos
Banned
thanks khani
hope i get some though
i know they do have the bigger ones
i was hoping to maybe get the 5 6 7
or even if i can get the moulds
im trying to get a guy to make the moulds but sourcing the wire is damn hard i cant seem to find the right thinkness
cheers riymos
and thanx bru
Calvin
Hi Riymos / Imraan
Have u tried Gone Fishing in the Gateway ?
Its owned by Basil Manning but just trading under dat name......
If not i'm going down der 2morrow.
I can get u sum !!!  Let me know !
Imraan u as well.....let me know if u need anything from der !!!
Tite lines
Calvin:)
Ian F
We make our own grapling sinkers. I use spring steel wire (get it from a factory that makes springs). The wire does rust, but by the time it's rusted, you've normally lost your sinker anyway.
These work particularly well in the rocks, as the sinker seems to bounce off the rocks when reeling in.
Riymos
Banned
hi ian
any chance of me finding a supplier here in durbs
also if possible maybe u can courier me a sample
ill pay for the costs thanks
riymos
jace
Hi Riymos
For spring--which is actuall high tensile steel you will able to get from E>E>Tarr in Pinetown..you would need to give the diameter and lenght of the products you looking for..if you looking for small lengths you might be able to source their offcuts at a reduced price...tel 031-7172251  or Springrite 031-7053515.
Good Luck
Jace
Riymos
Banned
howzit niv
the moulds im almost sure t have in abt 10 days
its the steel im having trouble with
if possible check for me and well keep in touch via fone
thanks boet
riymos
