Rusting lures
mouse .
As lure anglers we are constantly changing our lures during a session and continously expose numerous hooks to the salt.
The amount of fish missed and lost due to a rusted hook is large as opposed to a new sharp hook. Not only does it blunten the hooks but can also stain lures.
Is rinsing your lures off after each session the only alternative? How can we delay the eventual outcome? Lets see what you guys have to say.
In the mean time tight lines everyone:wfish
justinF
I am keen to hear the feedback on this from the pros.
I have just finished packing my fishing stuff for a 17 day trip to Wavecrest on the Wild Coast. Trip is only in three weeks time, but I am that excited that I packed today. Part of my packing, checking and maintenance was replacing rusted hooks and split rings on spoons and lures. The cob are going to take a hiding from me this trip!!
JVW
I am also keen for feedback.I have also just pack my stuff and some old hooks were really rusted.I soaked them in battery acid for a while and rinsed....but what now?
Not wanting to use Q20 or oily stuff,I looked in the wifey's place." COOK'N BAKE" or spray and cook-it smelled nice and sprayed my hooks and packed away in plastic bags-I will see end of April if it worked.Just a suggestion.
Good luck and I hope you get your big one or two.
Greetings
Jannie.
Fanie
Waaaat !
Koop julle nie nuwe tackele van voor af na elke trip nie ?
Dit is maar moeilik, die eerste ding is moenie dat jou visbokse water in kry nie. As ek in of naby water dan gebruik ek een van daai koelerboks rugsakke, veronderstel om waterdig te wees - ek sien nou die zip se handles breek af want hulle is deurgeroes :-D
Die kunsaas wat jy gebruik het kom eers in 'n ander houer waar jy dit in vars water kan uitpoel voor dit teruggaan.
Waar ek kan koop ek vlekvrye staal hoeke.
O ja, en my een pel is vreeslik netjies op sy tackle. Ons IS mos vriende so hy gee gewoonlik nie om as ek met sy goed vang nie ;-)
Ok dis net 'n grappie.
Alley Cat
Next time you have sardines in oil keep the oil, you then keep your hooks in a zip lock bag with a little oil in. I'm told this works, never got round to doing it myself.
Koper
I've seen this trick by one of the old hands on site when I visited his home.  All his lures are stored in a tin filled with some mazena/flour, this is suppose to draw all the moisture away, preventing rust.
Seems to work on his stuff.
Fanie
Ja nee Koper, jy't vergeet om te se van die huismoleste oor daar kunsaas in die koffie, meel, rys en koekmeel is ;-)
Vetvis
Ek gebruik daai pakkies wat saam met pille kom.
You know those things in shoes and stuff that says "do not eat"
this says... do not eat but then it says "harmless absorbent"
JVW
haha,Dis goeie raad-ek weet waarvan praat jy.
When I get back from a trip, I fill a bucket with fresh water and salt assassin. Every lure gets dunked in there, washed / rinsed then hung up to dry. Do not rinse the Salt assassin off!
Then I pour the salt assassin over my reels after rinsing them with fresh water.
Koper wrote:
Bennie
Salt Assassin - Tell us more please, first time I hear about it?
We use it to rinse our motors...
I use a cap full in a bucket, so it goes a long way.
http://www.killerdeals.co.za/salt-assassin-litre-p-2209.html
While salt may be the spice of life …good for taste and preserving, it certainly is not the skiboaters friend or for that matter, any salt-water sport lover using inboard/outboard or jet engines.
The good news is that this age-old enemy has finally met its match in the aptly named Salt Assassin, a great new SABS-approved product now available from Lowrance South Africa.
This water-based treatment can be used while flushing an engine’s cooling system. Salt Assassin breaks down and removes salt and corrosion, leaving the motor rust-free and protected.
To treat over-heating from salt build-up, an engine can be flushed sequentially every 24 hours, two to six times, depending on the severity of the situation. To prevent build-up it is advisable to flush an engine with the product after every use in water.
Plugged into a trigger spray, even valuable fishing equipment and tackle can be cleaned with Salt Assassin. In fact salt can be removed safely from any surface including magnesium, aluminium, steel, copper, brass, plastic and any areas exposed to salt.
You can even use it to wash your car, particularly if it has been exposed to salt water or is parked outside in the sea air. It does not strip wax or bond to surfaces and is 100% non-hazardous, non-toxic and biodegradable.
jared
Hi Guys
As a rust remover soak your hooks in some Coca Cola,  below some backround
many carbonated beverages will remove rust. This is because the gas used, carbon dioxide when mixed with water, makes carbonic acid. To make rust, the iron oxidizes - it combines with oxygen. This is why rust is also called iron oxide. The carbonic acid reverses this reaction - this reversal is called "reduction." Here's a better reason - take a look at your Coke can - it has phosphoric acid as an ingredient. Phosphoric acid is the basis of Naval Jelly, a commercial product used for rust removal. Phosphoric acid dissolves iron oxide very quickly while etching metallic iron very slowly so you can leave metal in phosphoric acid with little damage.
The downside is that all acids contribute some hydrogen to the metal structure, weakening the steel by hydrogen embrittlement - so always use only as much time as is absolutely necessary to remove the rust. An advantage of phosphoric acid is that it leaves a fine protective coating of iron phosphate. Because this coating is not thick or durable some protection is still required. Years ago supposedly Volkswagon use a process of phosphating metal prior to painting as it provided a chemical protection against rust under the paint layer.
j
Kenty
benniejordaan wrote:
IMO If a hook is rusty, throw it away and fit new ones. It really isn't worth the effort of reviving them!
:SSS..VERY WELL SAID!!..couldnt agree more!!..when the hooks on my spoons get rusty..throw away and replace..:SSS
Vis Burger
Hi !
I use salt X also like salt assasin .
But when ipack my lures i spray them with WD 40 !!!!
Believe it or not you can spray this stuff on any tackle ,it consists of 90% fish oil anyway so its like a fish attractant .
Google it and check it out !!!
NO LIES !!!i have caught plenty fish with my Rapalas sparayed full of this stuff .also protects!
Vis :kaykak
JVW
Vis Burger wrote:
Hi !
Vis :kaykak
Hallo Vis,
              Waar koop mens die salt x en wd-40
Ben REINERS
Ek sien dinge so tov my lures & dan natuurlik tov al my ander tackle -
Terwyl ek by die water is , hou ek al die gebruikte eind-gerei een kant in n aparte houer , om sodoende nie die ander gerei aan te klam nie.
Al is dit nou een outing vir n dag, of paar dae. Ek gaan deur dieselfde proses elke keer.
Dit sluit in alle gerei wat gebruik word ,van my lures , gewigte, swivels, hoeke , bait clips, tot my soutwater kuns vliee, messe , gare-houers ens.
By die huis gekom , word alle gerei in n skoon houer met baie ligte seep/ warm water geplaas, afgespoel , en gelos vir sowat 2 ure. Dan word dit afgespoel met skoon warm water , goed afgedroog , & in n plat plaat-houer geplaas, net soos n skink- bord.
Strooi mieliemeel oor die gerei soos lures hoeke, swivels , clips, traces, ens , & los vir sowat 2 dae om alle vog uit te trek. (Ek gebruik nooit meer as n halwe koppie meel nie)
In meeste vd gerei kompartmente & saam, met my lures het ek klein hoeveelhede “moisture-sachets” wat help om vog uit te hou (Die soort  wat verkrygbaar is in medisyne botteltjies)
Selfs my lyn op elke katrol word afgerol vir so 150 tot 200m , & word terug gerol met die hulp van n lou nat lap om die sout op die lyn af te vee met die terug-rol slag. So word moontlike swak plekke in die lyn ook op getel.
Al my stokke wat gebruik word kry n deeglike afwas met n spons & lou warm water , & natuurlik alle katrolle word deeglik afgevee met n warm nat spons & weer met baie ligte laag olie afgevee (Salt assassin soos genoem reeds).
Katrolle word gereeld “gestrip & gediens”
Let wel lou warm water, & nie warm water wat die verf & glans van lures en ander kuns ase sal  benaadeel nie.
Buiten die instandhouding vd gerei, word enige swak of defek op alle gerei gou opgetel , & jou gerei is reg vd volgende trip.
Dit klink na on- nodige werk & tyd ,maar glo my dit spaar baie geld.
Ek bly lief vir my stokperdjie & sorg dat dit dan reg is ten alle tye vir my en my seun se genot die volgende rondte , & hy ken al die “dril” as ons huis toe gaan na n dag se vangs.
Nodeloos om te se , al is hy 17 & dit nie sy sterk punt is om so te staan & skoon maak nie,  geniet hy dit tog , en dis wanneer ons oor die dag se gebeure chat & veral oor die vis wat ge-byt het of wat weg gekom het.
Dit bly darem n fantastiese sport.
Jammer MOUSE - Dit was nie oor LURES alleen nie ! :SSS:SSS
