Rods weight? Drag setting? All the small things...
Rorke
Ok this is probably a stupid question to most of you guys but what does it mean by 3.5lb by WT on a rod? or instead of saying WT it says 'action: 3lb'... I have a rod saying CW:60-100g (which I assume is cast weight), so are they all referring to cast weight or is there different meanings?
Then the drag on reels...since there are no numbers how do you know what you setting it to? Or must you just start at zero and work out what each click represents? And how do you know what it should be set on? Like does setting your drag to 5kg mean if you have 5.5kg line and hook a fish, the drag will release just in time, but if you have 4.5kg line it'll snap before the drag comes in to play? Or does it mean something else? I've been setting drag by feel or as low as possib
jonathanw
TC refers to Test curve, it defies the action of the rod, the higher the TC, the stiffer the action and casting power usually will be, most general specimen carp rods are usually 3.5 LB TC.
For the drag on the reel it is dependent on the reel how many ever clicks is needed to get to specific tension.
Generally when setting drags for fighting fish for example, if I am fishing 4 KG line I will fishing 1/4 drag of that breaking strain, so around a 1 kg of drag, can measure with scale, remember knots and terminal tackle will affect end knot strength, not advised to fish to heavy if fresh water, only tighten fully before casting so the line does not slip on the cast, then adjust according after you have casted, I feel by pull the line from the spool to the range I need more or less.
