Rod Transport - Pool Noodle
Psy
Hey Guys, found an interesting topic on the net, thought Ide share it with all of you.
Use the Pool Noodle. Cut a slot for your rod in the pool noodle and wrap the rod inside the pool noodle and viola....protection.... when its stuck inside the car's window. No more rags, T shirts, towels etc....no more scratches, bumping and knocking while you are racing away to the next fishing spot!!
Tight lines
OFC
great idea!vvidevb  i use that black hollow foam stuff the aircon guys use to wrap around the aircon pipe when i tie my one piece to the bakkies roof rack! works magic!
Good plan that!
Another use for a pool noodle.
Cut strips so you have rings about 25mm thick. Then wrap your traces around it. I use a toothpick to hold the swivel in place, wrap the trace around and hook the hook into the foam.
Dorado75
benniejordaan wrote:
Good plan that!
another great idea!!! i recon more pool noodles are used for other uses than what they were actually designed for!
Dorado75
i just thought of another great use for them, when i am launching my ark or when you launching the ski from a flat surface you can use them underneath to roll the small craft!
