Rod & Reel Selection
G-Rob
I've been away from surf angling for about 8 years now and want to get back into business. I'm kinda stuck between choosing a Saltist 30H or a Torium 30? I also would like to know, or if there are any suggestions, about rod selection. Im about 1.94m tall, would a 14ft surf rod be good? Also, do I go with a medium or heavy tip rod? I will mostly be targeting edibles and the occasional shark. Any sugestions would be greatly appreciated!!^^..
Exavier
:welcomesea:Well this only my uneducated 2c... i would definately go with the torium30 as im a devoted shimano fan. Rod of choice... most rods come with a heavy tip aswell as a medium/light tip. Depending on how much you would like to spend. Cheaper rods i would go for the beach master (2 tips, trigger and bag) shimano exgage also a good choise. If you have the moola go for sumthin like the pentagons. The best is to go fishing with a couple of guys and check their rods out and decide what type of action you like in a rod. Good luck.::tight:
G-Rob
Thanks Exavier. I used to usually use a 14ft, if I could remember correctly. Maybe I should just stick to that then.:fishn
Serra Moz
@ G - Rob, there's so many choices on the market nowdays, The top of the range comes with a "price tag" attached to it! Firstly I would suggest, you should have a look at your budget, once you've established you budget or max your are willing to fork out. My next step would be to check what I can get with my budget - now we talking quality ect...I have a Saltist 30 - using it on a smaller rod (14 ft - with very light line - brilliant combo) Thus I would not put it on a 14 ft if I intend targeting bigger fish (eds/non - eds) So, basically I would stick to the Torium as suggested, or take a Daiwa SL 50 (they are a bit cheaper - good all rounders that stood the test of time! Spool them with a bit of braid up 350 mts @ 35 lbs breaking strain - this will cost you a bit, then your nylon I would look at some decent like Double X or Kingfisher (I like Kingfisher) in the 35 lbs breaking strain. Rods, yes I will take a 3 piece for various reasons (1) Travelling (2) Space (3) 3 Tips is 3 tips - you can chop and change as you like!(4) Easy storage
Once again your budget, you get some decent Kingfisher Rods, send Khan (member) a PM and you won't be disapointed.
In brief, it's up to you - regarding (1) Choice (2) Budget (3)And what you want to target.
Believe each guy will tell you something different, however most will agree with budget and quality!
Good luck!
mikesfb
dont know too much about the choices but the torium 30 and saltist 30 are different sizes, i think. the torium 30 matches a saltist 50. for rod choice id go for something with interchangable tips so you can target edibles and inedibles.
Moyeni
Hi G-Rob,
A friend of mine recently brought a combo for R2650 it consisted of a:
1.Torium 30
2.Loomis 14ft - Heavy tip
3.Kingfisher Braid - 0.26mm - 300m
4.Kingfisher Line - 0.50mm - 600m (free)
What a lovely combination for edibles / sharks ect... Tackle shops always have good specials just shop around.
::mwird
neilg
I'll be in Stellenbosch on Monday, Tuesday and Wednesday
maybe we can hook up and talk about it over a beer. I provide info and you provide Amstel ...
what say u ?
G-Rob
I say engineering test week is gonna keep me busy this entire week, thanks for all the help though from all the guys.::slr::
G-Rob
Decided to go with the Torium 30 and a 14 ft exage. Read some reviews about the toriums though, reviews range between 5 out of 5  and 1 out of 5. Most complaints are with regards to the anti-reverse and gears seazing, and these people state that they have looked after their reels. But the funny thing was, most of the complainents mostly used Daiwa reels. Hidden agenda maybe?!
