Like Aqua mentioned about the "punch" cast - what your cast style? Your avatar pic does not give me an accurate indication of your size. You a strong caster that pushes through the stick or you cast with the stick allowing it to basically "pendulum" your bait out.Dont get any distance or action. And i , lol , aim straight in front of me but when i cast it goes way left haha. Very left
What purglass do you have? /2, /3, /4?What dia line are you using? Normally if i throw to much left it is when i try cast to hard - ie overload the rod! Try using a lighter sinker or a smaller bait! Do you cast left or right handed?
Remember its a new rod and you will get to know the feel, just practise!!
the exage doesnt take well to being punched, needs a good swing to get it going
now u tell me, i cant swing , then it goes even further left lmaoroland wrote:Like Aqua mentioned about the "punch" cast - what your cast style? Your avatar pic does not give me an accurate indication of your size. You a strong caster that pushes through the stick or you cast with the stick allowing it to basically "pendulum" your bait out.Dont get any distance or action. And i , lol , aim straight in front of me but when i cast it goes way left haha. Very left
If you not used to a stiffer stick it will come with more time.. The heavier sinker will help but ultimately you may have to change your casting style since you may have depended on the softer rods to do the "work" for you in the past.
I'll say you can be quite chuffed with yourself!Thanks. Used the light tip with 6oz sinker. Only casting. Did alot of casts. And i must say. Got the hang of it now. Measured 4 casts on the beach with my measure band and was quite surprised with the outcome lol. Nearest 90m , furthest 136m. If i can just average between 60 - 100m with a decent bait ill be happy
