Good luck guys, dnt 4get 2 use marine silicone sealer in the hole that u drill 4 the bolt..use 2 washers,pref rubber as well, u cn put a bolt and nut with washers on top and a pop rivet at the bottom,bt nt 2 low as u dnt want water leaking, let the pipe,50mm pvc, stick out a bit on top...i used clamps on the outsyd just 2 reinforce it as the bucket i used isnt that strong,bt i wanted it lightweight,i also attached pvc joiners 2 the top of the pipes 4 extra support, a taller bucket works better,perhaps you may prefer other alterations, ideal 4 rock fishn when therz no place 2 keep ur rod when baiting up, and 1nce filled with water, its v stable..lookn 4ward 2 ur pics
