Richtersberg Yellows and Catfish
peter elliott
I am doing a trip to Richtersberg (10 days) in June. Has anyone been recently  - what are the water levels and conditions? Did it two years ago same time of year and had success with smallmouth but want to target largemouth and catfish a bit more this time. Any local knowledge tips on patterns lines and retrieves?
will101
I have found the largies to hang around slightly downstream of the best smallmouth areas, i.e. more towards the main bodies of the pools at the tail end of the rapids. The smaller ones feed with the smallmouth in the rapids. I had one of my best takes on a crab pattern fished along the bottom in the quieter water below a rapid(one of those velcro crabs) but I unfortunately lost the fly. I suspect it was a large largemouth! Get them tied hookpoint up and add a weedguard for extra security.
The barbel are all over the place at night in the pools. I have not caught one on fly but my brother got a few on bait - I was SHOCKED when I witnessed the raw power of these things! I would not use anything smaller than a 9wt.
DJP
Havent fished richters itself lately but for orange largemouths try the bigger pools with baitfish imitations in green, black with a bit of flash. Topwater popers such as dahlberg divers or popers may also produce fish. This said most of the largemouths I've picked up was on large dropper flies whilst targeting smallmouths. The like to ambush there pray so look for areas where the baitfish can be trapped in little coves and crevases.
For the cats look for quiet deep water near reeds, calling the cats can be successfull and sometimes you can catch a few from one spot so if you hook one go back 30min later and try again. Use big profile flies in dark colours and fish near the bottom. Be prepared although winter isnt the best time for cats there are some brutes!!!
My 2 zim dollars.
peter elliott
Hi Guys - thanks for the replies and the advice. I always do a bit of research/reading pror to these trips which adds to the excitement. The literature I picked up on largemouth and the cats all confirms your good advice so thanks and now to stock up on a few fly patterns. The river is usually clean and low and temperature last time i was there in June +_16 degrees so hope it will make for good fishing. Will try to give some feed back if you are interested.
DJP
So what happened? Patterns? Fish?
Heading there next weekend for a day or two.:fswim
Going to try circle hook flies for the Largemouths, hopefully I get stuck less on the circles.
peter elliott
Hi
Things never turn out like they are supposed to be! The river was running at about 120 m3/sec (three times higher than my last visit) but relatively clear and still safe to get into the rapids in certain sections. We had a fishing ski and canoe and at Richtersberg camp the river allows you to paddle upstream with a bit of portage in search of rapids. Basically my son and I did mainly Czech nymphing but it took a couple fo days to get leaders and weights right (very important!) Flies all caddis types and almost exclusively brassie and red beaded (circle hooks). We caught a couple of teenager large mouths but believe it or not in 8 days did not get time to go after the big ones.If I can help with anything PM and I will help where I can.
Cheers and good luck
DJP
Thanks, last time I fished the richters I actualy caught some Moz tilapia whilst fishing for yellows.
Czech nymphs (shades of green with a gold bead) fished with a New Zealand style dropper and a PTN or orange hotspot nymph as point fly has produced some good results for me on the smallmouths.
I have also found that tying czech nymph patterns on Van Der Merwe style hooks work great for this application, the shape of the hook makes it sink belly down which reduces hang ups.
peter elliott
I tried the two fly set up but with the strong current they do not get down quick enough or do not get down at all and hence opted for the three fly set up. When necessary we also added small splitshot - small enough to get the flies down but not affect your indicator - when you get that balance right you are in business. My lesson was "learn from the experienced guys" i.e. spend a bit of time preparing the leaders and get the results.Also, when tying the Point fly tie to the eye of the Anchor fly rather than the gape (New Zealand rig) and the free fly attached to the leader with a simple loop around the leader and stopped above the knot creating tapered leader above the Anchor fly section. Probably sounds like gibberish but if you can check out Meintjies and Peddler Volume 1 Favoured Flies etc Page 52.
Please let me know how you go on your return.
DJP
Very true, if the fly doesnt get deep enough to move through the strike zone your going to find fishing hard.
I will report back on how things went. There is a few places I want to prospect.
Fished a stretch near Pofadder last year on a farm called Raapenskraap. Only people there with a large grassed camping area and excelent fishing waters. Only problem... its a bit of a drive!
DJP
The average size at Raapenskraap. Look at all that fishable water in the background!
DJP
We ended up going to Pella about 170km from Springbok for my first yellowfish trip of the season. We decided to drive through on Saturday morning despite the imminent cold front and the rugby . Got to the water’s edge at sunrise and the water was seemingly dead. Fished until 11h with only one moggel landed and then decided to rather go scouting for new spots. The water and outside temperature was very cold with a nippy wind.
We found a few new swims and decided to make a last effort at the one. Fishing heavily weighted flies (self tied no name) we managed some fish and decided to head back to the spot we first fished. Got there and picked up one of my biggest smallmouth yellows yet. My cousin whom outfished me on the day also got stuck into some nice fish and all in all the fishing wasn’t that bad considering the time of year and weather conditions. Good signs for the coming months!
