Hi Bennie, watched the vid and i looks good, saw what you're saying about the length of the pool, just as the lure start getting into the action the pool is finish
Anyhow looks good. A little heavy for us bass o's but then again that is a saltwater lure so the weight/sink rate should be more than "spot on"
Nice going there, as always!
Ps. The clear resin cast and the partial paint job, are you looking at making lures that seems like the belly's are see thru? Are you planning to lace the lures with some holographics at a stage?
That resin is really clear and you say it is not as brittle? Is t costly? Not into making the see thru ones as such, mine all gets painted so it doesn't matter, but on one occassion i wanted to do something as described above. Hence the cost question, cause i don't need liters of clear, 500ml will be enough, if it is sold in such small quatities. Also, what is the shelflife once opened?
Sorry for all the Q's and thanx in advance.
Keep up the good work man!
