Restoring my trailer and boat
Osie
So I bought the boat and the trailer and now I want to start restoring it on my own time. I know there is allot of people out there that can do this very efficiently and quickly but this is something I want to do on my own.
I have never done anything like this on my own so this is going to take a while and allot of learning. I will start with the trailer.
I need some advice on removing rust and paint from the steel trailer. According to an article that I read a Steel brush on a grinder should be used first and then a rust and paint remover liquid should be applied.
Is there any other suggestions out there.
pieterh
If you could , rather get it sand blasted and then inspect and cut out ,weld in new pieces,
The wire bruch does a good job but you cant get in every where with it.
cornelius
Osie,
There`s grinding/sanding disk that fits an angle grinder and works a lot better on paint and rust than any steel brush. It`s called a Face-off-disk, black/charcoal in colour and very rough/abrasive. Will strip your trailer down to bare metal in no time flat but the down side is that it wears away pretty quick.
Alternative is a flat edged scraper like the straight edge of a wood chisel. The paint comes off in little chunks and quite quickly as well. A decent heat gun or gas torch will also help for removing the paint.
Best of luck.
Louis aka cornelius.
Patrick
When i bought a 2nd hand trailer to replace my old one it too had rust that needed to be taken off. i found the best tool was just a plain grinding disc (not a cutting disc). Grind off all the rust until you get to bare metal. The wire brush tool also works well for areas where the disc cant reach. Just one thing i found tho, dont grip the grinder too tightly and try avoid using it for prolonged periods if you can. I ground my trailer for 2 days straight and i had pins n needles in my hands for weeks afterwards. Strangest sensation, which luckily went away. There is a medical name for it. If you can use some sort of shock absorbing sponge when gripping the grinder it should help.
Vrottes
PLEASE WEAR PROTECTIVE CLOTHING! Safety goggles cost R20.....An eye cannot be replaced ! Specially with the wire brush on the grinder ! Those bristles are dangerous !
Osie
After reading all your advice and two hours with a grinder in my hand last night I started wandering what sandblasting will cost me.
I phoned around a bit and realized it is not that expensive. As I said before I am new on this whole thing.
Is powder coating the better way to go on the trailer than spraying it myself?
pieterh
Good to see you are getting there.
Get the trailer HOT DIP GALV.
Powder coating with come off afer a while especialy if you nock and scratch it.
tauruck
I'm sure if you send it to galve it gets dipped first and it takes all the old stuff off. Check on it. If you go the sandblast route, do it now!!!! Before the rain comes. Your newly blasted trailer will be rusting by the time you get home if it gets wet.^^..
Osie
It's quite expensive galavanizing, more than double the price than powder coating. Is it really worth it?
Osie
I tried Robor Galv and they are charging me between R2500 and R3000 to do it where the powder coating is costing me R1400.00
Simen
Also phone Babcock in Nigel they have on of the biggest galv baths in the country.
Speak to Adriano Pavani--011- 739 8221
mudcrab
powder coat is a surface bond and will last 2yrs before it starts peeling,gal is the way to go will last 15yrs if done well
dodger
an alternative to galvanising is Hammerite paint. You need to grind all the old paint off to bare metal, my skiboat trailer is 6 years old and still fine, touch ups are required but it works for me :fishn
Warning about powder coating for anyone... It is pretty and durable but the problem is the trailer rusts under the powder coating and you don't see it. At least with paint, the paint bubbles and you can sort it easily and quickly before it gets worse as in dodger's case. powder coating a luggage trailer is fine, but not recommended for a boat trailers..
But ya, there is no substitute for a proper job and that is galvanising.
