Reel Sizes
Swagman
I often see people refering to 4000 size reels or 5000 size reels. Is this a standard sizing system across different manufacturers. I have seen diferent size reels using the same number ie medium size 6000 and huge size 6000. Can someone please explain this.
PS. Is it the same for multiplier reels? size 20, 30, 50 etc. please explain this also.
misguide
It is not a standard. The bigger the number the bigger the reel.
From my understanding the numbers mean zero - they are merely a reference so you know it is a bigger or smaller reel when looking at the same model and make.
The numbers vary on different manufacturers - example a Shimano TN50 is not the same size as a Daiwa Saltiga 50 - even though they are both 50 sized reels.
Swagman
Why then do do many manufacturers use the same numbering conventios across all their different ranges?  Daiwa, Shimano, Abu and Penn all use the 2000, 4000 etc. system. The same is true for the multiplier reels 15,20,30,50 etc
Shimaiwa
It is an annoying thing, you almost wish there was a standard system followed throughout, but I suppose there are too many variables with each reel to define a class size. Main thing to remember is just to compare line capacity
misguide
Dorado75 wrote:
for the multiplying reels does the number not mean the pound of the reel, ie Trin 30 = 30lb?
30lb of what?
Drag?
Recommended line?
So the Saltiga 50 has the same "specs" as the Trinidad 50 - according to what you are saying?
It is the same as cars every manufacturer does something different...i am sure it isnt the lb of line it can take or the strength of the drag .. it is just a ref to a model and as misguided said bigger the number bigger the reel
camo shorts
Hey have you noticed, cars, microwaves, fridges., cell phones etc, all have funny numbers :fbash, each manufacturer indicates positions of their product within their product range. So best thing to do is read spec sheets or look at different brands in a shop to determine where they fit relative to each other.
camo shorts
Sorry have to ask you MC which is a bigger reel Penn500 or Pen49?
Dorado75
misguide wrote:
30lb of what?
Drag?
Recommended line?
I speak under correction but i think it is something to do with the recommended line. Perhaps someone with the Salriga and Trinidad can comment on if they are the same size?
I am really not sure i have never used penn reels..so i cant not comment..i only use shimano and diawa
Dorado75
A Penn 49 is bigger than a Penn 500!
camo shorts
The 10 is even larger, so Penn use descending numbers for increasing sizes, Daiwa40 is same size as Shimano20, but Shim30 and Daiw50 is same size. Now I'm confused too, time for another coffee, I think
i agree camo shorts...to much to think of this early on a monday ....i thinks the conclusion is that before you buy a reel go check it out is the shop first to see if the size is correct for the application that you are going to use it for..
they way i see it is that every suppliers has there own ideas for what number they going to put on a reel ...
now for another cup of coffee
surfaMIKE
ok on the line capacity part. They should rather state it in the diametre of the line, not the breaking strain. Some manufactures do this, but most dont. I can load my penn jigmaster with easily +-450m of 30lb KFGA, yet it states that it can only take 275 yards of 30lb line, which is about 250m. The 30lb KFGA is 0.45mm, and in order for me to get 250m of line on my reel, I must use like 0.55mm. Tell me, is 0.55mm line 30lb? didnt think so...
i have to agree with you ...the manufactures specs are way out...it would be interesting to see how accurate they are with there drag ratings....has anyone put there reels to the test.???
rofflign
then there's the 49A which is even bigger..hehe! oh dear and then there's an 85 which is bigger than a 500 or is it the other way round, not to mention the 535 which is smaller than the 555 and a 505 which is the same size as a 500...lol ::teas::
i think you have had to much coffee this morning :fbash:fbash
