Hi Guys, I'm back ....sure you getting tired of me by now,
Anyway, I'm revisiting this again, I have ordered the oust bearing oil, have read very good things about it, BUT, it has dawned on me in 2 aspects,
I am fishing trinidad a reels, problem is, access to spool bearings!!!!
Secondly, the oust oil is very thin, therefore more regular oiling, dont want to be opening the reel up and having to relube and clean reel parts all the time due to this process.
I fishing the ceramic hybrids, so generally a thinner oil is required.
So, Im looking at input or suggestions, on,
1. Do you think I could mix a grease and oil together and make a concoction, with a slightly thicker viscosity that wont impact too much on the bearings?
2. Are there any thicker oils out there that could be applied but could be good for at least 10 plus sessions?
My last question is, my local rip off store has Daiwa oil, is this a thicker oil and what would you think about using this as a bearing oil for ceramics? Im all for new things and experimenting until I find whats the most useful for me....any thoughts?
and something else I thought about playing with, the corrosion block spray, not grease, how would that be as a bearing oil, it is a bit thicker?
