Read this article on new technology on its way:
Fishpaste
Not sure if anyone else except Solly's Anglers Corner in Nelspruit stocks it...
Only comes in 300m spools and 11kg & 19kg
11kg - 0.18mm
19kg - 0.25mm
3 colour options - Yellow, Green & Transparent
Fishpaste
11kg - 0.18mm
19kg - 0.25mm
With e above being said I jut learned that Mias Woodmead (JHB) also now stock GLISS so maybe just maybe you could get it at one of your local stores. Otherwise I cant see that Ganis wont have so you will be able to courier. Going rate seems to be in the region of around R350 per 300m
bassbug
350 bucks for 300m? sounds expensive considering whats been mentioned above. how much is braid these days for a 300m spool of the same breaking strain (its been years since i've bought braid)
www.tackletraders.co.za advertise the gliss but with no bliss pricing
Fishpaste
Pieter Immelman wrote:
Ek is in die mark as ek 300m GLISS kan kry vir R300,00.
The places I phoned are definitely not any of the cheapest stores around so I am sure you will get for around R300.
Maar net rond shop...Hierdie manne van Sandton rook ons lelik deur die ore!!!
I initially tried Sollys Nelspruit as they were the first to have...then tried a contact I know at Mias Woodmead to see if they have out of interest...since they do have I am sure everyone else will have or at least be able to get some for you. Sollys Nelspruit will give me 10% discount so we looking at R340. Mias...well like I said I have a contact so might get it very close to the R300.
sakn
I have not purchased as yet, but the report I have received thus far is that it does not knot well at all and is not as durable as what was hyped up.
Please check with someone who has purchased and used for at least a month or two before taking the plunge.
willem wikkel spies
ok, was vandag by western acc.
hulle het oo gliss.
gou daarna geloer en wat sien ek?
R 350 vir 300 meter 11kg.
ok kyk toe sommer na jdb braid.
die gliss was 0,18mm vir 11kg.
die jerry brown was 0,18mm vir 20lb, dus 9kg
Fishpaste
hulle het oo gliss.
Hoeveel kos die Jerry Brown by Westerns?
Raptor1
This newish Gliss line/braid product has been available around the UK for a few months now,and been widely tried by some top rated sea anglers.
Mostly from the shore using as a mainline for lures/plastics/plugs while lure fishing, and also for throw baits,admittedly for both types of fishing this was over mixed to rough grounds.
Sadly most reported back the same very disappointing results,very poor knot strength,multiple failures even when using all the various high rated strength leader jointing knots.Also after only one session,even with the use of tippet abrasion and casting leaders attached onto the mainline Gliss,this was roughing up and fraying badly.
Have nt heard one guy who was keen to use it again or to recommend
it.If you "google search" uk angler "Henry Gilby" website,there is a write up on his recent trials with this product and many comments
from others with their findings also.
Fishpaste
Welcome to Sealine Raptor1 :welcomesea:
Thank you for your feedback regarding the Gliss...stood with it in my hand this week and decided against it as my braid is still in top notch condition.
I will defo read the review,
Much appreciated! ::tight:
Raptor1
Thankyou for the welcome,excellent site cant believe have not found it before.
Slightly off topic,myself as many are doing nowadays in UK have switched from mono to braid mainlines for our shore fishing.In all conditions,all types of grounds from clean beaches to the heaviest terrain,deep gullies full of bamboo and boulders.Advantages far exceed the negatives,extra extreme distances with baits and bite detection at range you would never see on mono lines.As for braids we have found
allround you cant really look past 15-30kg mainlines plus a 50kg braid casting leader.Rig body traces are still built in 80/100lb heavy mono.Braids themselves after trying many you cant look past "Powerpro and Whiplash" in 30kg for rough ground,go down to 15kg for mixed/clean ground and beaches,all with full length to reel heavy braid leaders.
Mind saying all this we have retired our multipliers and are solely using top end big grinders for all this type of braid fishing.
willem wikkel spies
ok, something else.........
found gliss at a angling shop in Heidelberg. a dear friend of mine!
ok with him having gliss on the shelf, I took a closer look at it.
and as I normally do, put it between my teeth!
bit on it and pulled it through my teeth.
my conclusion was that it is very much the same as nano fill!
if bitten hard enough it becomes flat, just lie nano fill.
if you did this with braid, you will feel the "rifels", this gliss was completely soft, no rippling!
Jovis
I bought the 19kg but haven't used it yet. However, after reading the following article just now, I'm not so sure that I did the right thing..
http://www.henry-gilbey.com/blog/some-further-thoughts-on-this-new-gliss-mainline
tadeo
Not to hijack the thread ,but has anyone used the dip,master fight II evo braid yet.
I’ve been keeping a couple of bucks aside for when gliss comes down to us but saw this in my local shop today.
I may just get that instead
hotrodding
GLISS .... the specs of this line,..  right down to the problems sounds like it Berkley Nanofil in another wrapping...
Is it really any different ????
