Read this article on new technology on its way:
riekert
https://www.angling-international.com/new-line-tipped-replacement-braid/
I wonder how its knot strength, abrasion resistance etc. will be?
circa 64
Sounds okay, braid with a bit of stretch would be good, wouldn't mind trying it. Not much online about it, will have to wait and see. Probably take a while to get it into the market place.
Abaddon
Maybe Enigma can shed a little light on the matter?
Linked to me on FB -
A new line so thin and strong that it could replace braid is about to be launched into the market.
The company behind the development is World Fishing Tackle (WFT), which has been working on the secret project for two and a half years.
The line, called Gliss, is made from extruded hmpe fibres and according to WFT’s Managing Director, Christian Dibisch, combines the qualities of both a monofilament and a braid.
“Gliss looks like a mono, but has huge advantages, including almost zero stretch. Other lines have at least three times more stretch,” Dibisch told Angling International. “It also has extremely low diameter-to-breaking strength ratios. At 0.010 diameter, it has 4kg strength.
“These exceptional properties give it multiple applications. The low stretch means it is incredibly sensitive and you always know what is happening under the water.”
The potential for Gliss is further boosted by the fact that it can be produced far more quickly and cheaply than braid. Dibisch estimated that it takes around 100 hours to produce 1,000 metres of braid, depending on the type. But he can manufacture the same length of Gliss in a matter of minutes.
“Production is so fast that I am sure it will replace braid in certain fields of fishing,” said Dibisch. “It is ideal for any application where low stretch is an advantage, such as lure fishing and long range fishing. Light lures can be controlled more sensitively than ever before.
“What we have introduced is actually a third generation product,” added Dibisch. “The first and second generations were developed during the testing phase as we worked to make the line as good as possible.
Arno0309
Seems awesome, saw a similar post today and followed the link, I was wondering...
The 0.010 diameter, is that inches or millimeters... Either way, that is very impressive...
Would like to see:
1. What the abrasion resistance would be like for fishing between the bricks?
2. Can it be used as main line to replace braid on a multiplier reel?
3. How much memory does the line keep?
4. What is the knot strength like?
5. What diameter / breaking strains are available?
6. What colours are available?
7. How much does it cost and how can one get hold of some?
Keen to see how this thread goes...
::slr::
As far as I know no-one but their products are distributed by more than 1 distributor.
If this makes it to market and is viable I'm sure one of the distributors with the budget to market and stock it will pick Gliss up in a hurry.
that guy
Enigma wrote:
Inches
Not yet commercially available
The report seems to be just a teaser
if its inches that's 0.254mm which is hopeless by braid standards for a 4kg breaking strain. Maybe all the hype is just hot air.
brandonz
Gliss finally Coming to SA!
Gliss Kg Facts:
• Extra thin (19Kg – 0.25mm / 11KG – 0.18mm)
• No Memory / No Stretch
• Low friction – Record casting
• No coating / Perfectly round
• High abrasion resistance
• Absorbs no water – Very durable
• Made from 100% HMPE (High Modulus Poly Ethylene)
• Manufactured by Nippon Dyneema Japan. (Owned by WFT Germany)
• Cost effective
Gliss KG compare to Braid:
Braid is available in 4, 6 and 8 strands, these strands need to be woven together. To manufacture good quality braid is an expensive process. Gliss KG on the other hand is a Mono Strand line made from HMPE. The Manufacturing process is faster and more cost effective than braid. Estimated SRP should be less than R400.00 / 300m
Gliss Kg will be available in South Africa early July 2015
• 11Kg (0.18mm) 300m spools
• 19kg (0.25mm) 300m spools
Both breaking strains will be available in Green, Yellow and Transparent
circa 64
It's being brought in by Tackle Traders in Nelspruit , should be here early in July according to there website, unfortunately they don't sell direct to the public so we'll have to wait until it gets to the retailers.
If you check the profile brandonz is from Nelspruit and associated with Tackle Traders hence his heads up
willem wikkel spies
so will the normal knots work on this line?
just wondering as with nanofill one had to jump to new knots as the normal knots kept on failing.
sal maar moet sien
Something like braid, with a little bit more stretch, cheaper, limp, more abrasion resistance (slightly larger diameter), available in heavier lines and ties like nylon...that sounds like a winner.. we will have to see the first reports that come in, the first tests in the mags are sponsored but it sounds like an viable option to braid which has its drawbacks..
