As you know I have a Jm ps 200g conventional, I want to ask you if I can use the rod with a spinner, I mean I know I can but will I do any damage to the blank? etc ...
Yes it is possible to use it with a spin reel but this is not advised. You will be using the rod "upside down" - opposite to the spine that it is built on. Also the small guides will inhibit casting and the trigger grip will be a pain in the hand (arse).
JM rods are a high performance conventional rod, please don't use it in any way that it was not designed for.
