Putting Braid on my Shimano 20 40s
Corkscrew
H Guys, thinking of putting backing braid on my reel.
Thought bout the Kingfisher braid. How much should i put on to keep a good balance. Thought maybe, 300m braid and 300m mono 30ib test
Arno Nel
300m of KF Pro Braid or Whiplash would be perfect. Contact Gremlins for HMP braid. R0.90 per meter.
You should be able to fit 250m to 300m of 0.45 nylon after loaded with one of these mentioned braids
Paulus
Hi Guys
You should soak the braid for 24 hrs before you spool it.
It will loosen on the spool and you must remove it and respool after every few outings.
If your spool has no centre pin you should have a meter of mono tied on first and tie the braid to that.
Hope this photo is alright to put up.
Paulus
more info at
http://www.pcwi.com.au/fishing/
if you want yr line tested free send some in
steve m
i used to have 250m of 50lb pline braid and then about 400 to 450m 0.40 as top shot but have since changed to 300m of 0.60 topshot for sharks around reefs and as a back up for my trini and torium so i recon that you should get what i used to get.
steve m
No for cob and elf and so on, but i did get a couple of smallish smooth hounds on it and a eagle ray of 25kgs(flipping strong fish!!!!!)
