Purglas 400/2 3 Piece
Dorado75
I managed to find a Purglas 400/2 3 piece rod yesterday at one of our local tackle shops, it had apparently been in the shop for a while so it had a couple of small scratches on it, so i got it for a excellent price!
Are any of you guys using the same rod and how do you rate them, one other thing is that the rod parts do not seat right into each other properly, the salesman said that they will eventually with time....... comments here??
POSTHUD
All the pruglas 3 piece rods I have seen did this - there's a gap between the pieces, but that doesn't necessarily mean they don't fit...
Contact Purglas directly and confirm with them - (031) 301 6090 - they will give you a straight answer and no salesman mumbo jumbo..
Pylstert
It is exactly how they should fit. They make use of a ferule instead of one section fitting into another. There are some flyrods like Scott that also work like that. Purglas makes the entire blank, then they cut it into 3 pieces and fit the ferules and strenghten the female section. They reckon the rod has a better action like that
Walt
Tuna Fish bought same 3 pce from Suburban for under a Grand(R1000).If you don't get a satisfactory answer send me a pm and I'll give you his nr and you can always check his rod,and confer with him, as he's in Marina Da Gama.Cheers!
