benniejordaan
Hi guys,
I will be installing this over the weekend. I am moving my 100AH battery to the front and refitting the original 45AH at the stbd side.
This is how it works:
Instead of using your motor's battery to power your electronics, you use and auxiliary batter. Another option was to fit a series of small 20AH batteries but I already have the 100AH so I'll use it. The unit allows each motor to charge its own battery, once they are fully charged, it diverts the charge to your auxiliary battery. It then isolates the auxiliary battery so that you cannot draw power from your motor batteries. Should the power on the motor battery drop below 11 V usually from starting the motor or standing it then switches over to charge the motor battery again until full.
The main advantage here is that you do not use you motor's power required for starting. Also you now have both motors charging the auxiliary battery so that one charges up in half the time!
The components are sealed in resin.
It is built by P&M Mechatronics (Peter) 0827248658 Cost was R750.
