Power Handles.
AndriesH
Good stuff Bennie & thanks for including us in your venture:
http://bluecity.co.za/oscommerce/index.php?cPath=77
Bennie has offered Sealine a 10% discount and we'll do the same by sponsoring the postage. We will assist Bennie in getting a database going as fast as possible, resulting in better choices for us fisherman.
pieterh
These handles are lekker.
They work like a bomb and they make the reel look gooood.
I check Bennies ones out on the boat the other weekend, just exclent.
Well done Bennie .:first
shagnrelease
hey bennie, have you measured up an older style Tiagra 80w? I have one with a kak handle, the newer ones are fine but i would not mind one of these? What measurements do you require?
Howzit SnR,
I'd prefer if you could send the reel to me, I'll measure and fit the handle and send back to you!
Shipping will be for my cost!
sardinella
Hi Bennie and everone else,
Any news on power handles for spinning reels that I can source locally.
I need to change the handle on a Tica GG100R that my wife is using for bottom fishing. The factory fitted handle causes blisters on her hands.
Hi,
There is an option. I took one of my power handles and fitted the handle to my existing Okuma shaft. Just drill the old pin out and bolt the new one one. Fairly simple. We can supply these handles without the lever for R380. Speak to AndriesH.
Bennie
Hi John,
I am not sure of the dimensions of the shaft, it might be the same size as one of the other reels but I'm not sure. I can custom make the handle.
A better and more cost effective option is to drill the pin on the existing arm and bolt this one on. Or get it to us and I'll do it for you at no extra charge.
Bennie
strandloper
Bennie,
Fitment to a Daiwa 450??
I managed to get my dad's unused one and now want to pimp it with handle, washers and some serious braid!!!
Let me know
strandloper wrote:
Bennie,
Let me know
I don't know. The thing is even though it might be similar to another reel, I can't be sure that the keeper screw is in the right place. I'll check if someone in Durbs has one to compare.
If you have a penn 49, can you check if that handle fits? They look the same design and I have noticed that a lot of the reel manufacturers have been buying handles from the same source.
Awief
Hi Bennie,
Good stuff.
I also need handles same as SNR for two Tiagra 80W reels, and one for Daiwa Sealine SL50SH
BR. AwieF
strandloper
benniejordaan wrote:
strandloper wrote:
Bennie,
Let me know
Think there is a 49 around somewhere. Will let you know
