Old legendary Spoons or "Spinners"
kitefisher
Hatatatata, Hier's darem n paar menere hier.Hoe meer ek kyk na die potensiele effektiwiteit van die ouer lepels ,hoe meer besef ek ons word gebreinspoel om te glo dat net die nuter lepels werk. LMGA.
Great pics Ben.
tackle whore
Who made Jensen spoons in its day it carried a RSA Pat#? I managed to salvage a whole batch of them from a scrap yard mixed in with my lead I collected .
Ben REINERS
Jy is 100% korrek Allan.....my opinie is dat ons as mens word gou aangetrek tot "bling" in die winkelrakke & ander hengelaars se stories....veral as daar mooi fotos by is om dit te bevestig.....dan is daai lepel " n must have" in ons tackleboks......maar ons vergeet dat die "golden-oldies" ons goed gedien het met goeie resultate....maar hulle word opsy geskyf....gaar stof....
It will be interesting to know where Jensen comes from TW..... or who made them ?
Jacquesdw
Thank you very much for this post! Really enjoying all the spoons.
Where can you still 60g Abu Toby's? Can you get them bigger? Homemade??
What I would love is a tin copy of Iron Candy SV#3 coming in at 60g. Anybody up for the challenge?
kitefisher
Jaques , The Iron Candy SV3 comes in at 90 grams.Pure Tin(if you can find some)is roughly two thirds the weight of lead.
All you basically need is a mould of the SV3 in its 90 gram size and then pour it using pure tin and you should be pretty close to your desired 60 grams.
Bear in mind the following couple of thumbsuck tips.
At the same dimensions, but now of a lighter weight your 60g version will cast differently than the 90g.Not only the weight factor, but also the fact that you have the same areas exposed to wind etc ,but with a lesser weight.
The same will hold true underwater.Same size areas exposed to the water will give you similar action,but at a much slower retrieve speed.(due to it being lighter)If you opted to retrieve at the same speed as the original SV3 90 Gram,you may even be disappointed in the action at that speed.
However, for a specific application, for example.If you want a big-body spoon in the zone for longer ,or perhaps higher in the water column,but at a slower retrieve,then you may be spot on with your reduced weight/similar size-idea.
Just points to ponder.
p.s an Abu Lucas made of white metal at 60grams like the ones that TW lURES sell may just do the same job and will probably be more cost effective than the Tin option.
Jacquesdw
Thank you kitefisher! That's exactly what I want! There are some shallow rocky areas that I want to "float" my spoon over.
BTW, the SV#3 weights 73-75g with hook and splitring. Most spoons in SA are off on their weights. I regard a small digital kitchen scale as an essential equipment. Some are off by 15g! on a 2 ounce stated weight!
Ben REINERS
Using old pieces of scrap lying around......bending & adding eyes & bling..........use them in salty rivers/estuaries
kitefisher
'''Thank you kitefisher! That's exactly what I want! There are some shallow rocky areas that I want to "float" my spoon over.
BTW, the SV#3 weights 73-75g with hook and splitring. Most spoons in SA are off on their weights. I regard a small digital kitchen scale as an essential equipment. Some are off by 15g! on a 2 ounce stated weight!'''
Jaques,I also like to have a scale handy when fiddling around with lures and spoons.One can appreciate that not all mixes of lead are going to be exactly the same density,but a variance of 15 grams on a 2oz spoon(as you mention above) is perhaps a little over the top.One could actually ask if you are getting what you are paying for.??
Imagine that variance on a Kruger-coin ,bwahahaha.
If memory serves me right,then WM90 (White metal) is roughly 10-12% lighter than lead .Again then if you got somebody to make you a mould of your current SV3 @ 73g; (90G as per their website,not that website's are always correct),and you poured it with WM90,you would probably have a spoon of around 65g (73g-10%= 65.7g) .
I know the feeling when you have absolute faith that a particular spoon will be perfect for a particular scenario that only you have visualized already.I say go for it because the satisfaction will be well worth it when it pays off.
The range of Basil Mannings' spin-specific spoons have arguably accounted for more fish between Richards Bay and Port Edward than all other spoons combined,(not even counting other areas and international successes(Aus etc),However until you have that SV3 in 60 grams dangling off your rod tip,you may just find another ''standard WM90 spoon at 60g that may do the job you are after.
kitefisher
Ben ,ek het self so paar van hulle,Eintlik ongelooflik hoe hulle hul gatte kan wikkel.Swem baie soos n ''Lazy Ike'' kuns-aas.:)
Ben REINERS
N lepel wat ek by n pandjies winkel opgetel het & op beide kant reflector tape geplak het...........Dit is ongelooflik die verskillende spektrum kleure wat verkry word op verskillende dae tov helderheid vd son/lig........
Ben REINERS
My eie "slim-spoon" ......saam n KF 2V net om sy vorm & groote te vergelyk.
Gemaak uit WM.
Ben REINERS
Nog een v my WM lepels........of sal ek se lepeltjie..............
Ben REINERS
Dit is so Allan, agv hul lig-gewig moet n mens hom maar baie stadig trek v n goeie swem aksie........en so nou en dan n plukkie of 2 gee vir ekstra aksie....
Ben REINERS
Ek het hierdie Abu lepel wat n shad slayer is..........
Ben REINERS
Dis waar........ek moet nog net by die snoek spots uitkom & probeer........wat ander spesie aan betref werk hulle goed.....maar daai elusive snoek sal ek kry met hulle.....:)
