Okuma Trio 5500
JVW
BlikkiesGerber wrote:
James, you must have the worst luck of all the fishermen I know... Either that, or your just the most vocal... If your not popping a power swiwel(that suck) or pulling a circle hook(that suck), your breaking a rod tip(that suck) or having a rusty grinder(that suck)...
Btw, with all the Shimano tackle you already have, you should know their quality, why buy anything else? Having said that, I suppose its your choice and has nothing to do with me... Maar, die oumense het geweet waarvan hulle gepraat het toe hulle gesê het..."goedkoop koop is duur koop"
Hope you luck changes! ;)
Ek dink Stapies kan nie vis vang nie,nou blameer hy die tools
Cpt. Hook
I have 12 Okuma Trios that I use for my charters and they are about 18 months old and I have no rust problems with them whatsoever.
I also have 20 Okuma Salina Reels and one of them had a problem of the anodising coming off on the rotor and Midas sorted this out for me very quickly with no trouble at all.
When washing your reels, you NEVER just pack them away immediately, you need to allow them time to dry out, other wise you will have problems due to condensation.
Give Aslam Hassan a call at Midas in Durban at the numbers above, he will sort you out quickly.
