Okuma Trio 5500
Stapies
Hi Guys,
I decided to buy myself an Okuma trio 5500 a while ago to test it as I heard good things about it... My first outing with the reel was to Dassen Island and my first tail I hooked the grip on the handle came off! I kept it and later I glued it back on. Thinking it was just a mistake they made in the factory.
After that I used the reel about 5 times and never got the reel wet. I like to take care of my tackle rinsed it anyway after every fishing session. The reel was packed away for a few months and the other day took it out, turned the handle and the next moment the reel got stuck. Vas!
I did not want to force it by turning it and I decided to take it in to get a decent service and I hoped it was something small...
I was horrified by the outcome! The anti reverse bearings and some other bearing only okuma can supply you with is vrot! Damaged and beyond repair...
I also hear that okuma's after service is terrible!!! This is ridiculous.
Do anybody on sealine know who I can contact in regards to this reel and the bearings? It is unacceptable that you buy a reel only to be able to use it about 6 times.
Strepie
Akals(Midas Group) is the distributors.
Website: www.midas.co.za
Mobile: 083 630-7508
Telephone: (031) 313-2000 , (031) 313-2021 , (031) 313-2128
Fax: (031) 303-2498, (031) 312-3807
Map
Street Address: 270 Stamford Hill Rd
Stamford Hill
Durban
4001
Postal Address: P.O. Box 1725
Durban
4000
setobla
eish, not a lekker experience Stapies.
lyk of okuma of baie goeie katrolle maak of baie l<@l< katrolle. Finchasers hou vir jare.
Stapies
Look at this!!! Mild steel prob... And this in a saltwater reel...
Zayne
Trio Have a 3 year Warranty
I know guys down hear in PE that use the 30 40 and 55 and have never herd anything bad of the reel until now.
tjopsie
Hi Stapies waarvan moet die ratte gewoonlik van gemaak word in die (see) geval?Stainless steel of Brass?
ek weet baie van die varswater katrolle se ratte is Puter.
Stefan001
My trio 65 lasted one season of spinning. I use it now for gallie fishing till its really broken and then I will buy something decent.
Katot
BWhahahahaha a trio is an awesome reel for its price. You get what you pay for. It is not a sustain, stradic or anything similar. If you were looking for an okuma that will be closer to those (but not yet there) then Okuma Salina and Raw would have been a better bet. The Trio is awesome in rivers fishing for bigger game like cob and garrick, but for the price you pay for it care should be taken not to get it wet.....at all costs. But dammit for R400 it is good, and yes I own Daiwa and Shimano and still my Trio 30s is my favourite(with the cheapie reels)....going strong without any services for 2 years......btw washing a grinder of with normal freshwater is grinder suicide. Rather do not wash it off, and clean it every third trip(this is aimed at the cheaper grinder ranges). I fit does not get wet, then there will be no problem...the odd splash will not do damage. But constant salt spray(like off a boat or on the rocks where big waves are running) will be the death of most grinders.
Fin-S
Sorry Katot, but I disagree. Why buy a fishing reel and then say, don't get it wet. Kind of defeats the purpose - like here is a rod just don't bend it.
Katot
Bud the same goes for all grinders. If it does get wet, then you have to open it up and clean it. Washing it down with fresh water will not work. That is what is meant with do not get it wet
Katot
And by wet I do not mean the odd splash....either wading or constant salt spray. I have had my fair share of grinders...both expensive and cheapies.....the result is the same......btw this does not include those reels I can not afford like the Sustains etc
Stapies
Ek het regal's en crossfires wat beter en langer hou. Selfs die combo cheapie R150 katrolle wat kinders mee vang hou langer!
Ek het baie tackle en nog nooit het ENIGE van my grinders dit gedoen nie. En ander grinders het ek op my kayak gebruik waar hulle baie nat word! Almal nog 100%...
Okuma SUCK!!!!
frank22
the reel you are using Okuma trio 5500 was designed for targeting the large catfish you get in spain and portugal , it is mostly used for freshwater.
okuma lied to you by advertising this reel as a saltwater product , it is an inshore reel meaning that the water is not as salty as the sea. there are no seals on the reel if you open it and have a look it is open to the elements , even when it rains.
all the parts in an okuma have mild steel parts and will not hold upto any saltwater conditions. the aluminium they use is also not treated for saltwater so corrodes very quickly.
i always say to the wife when she complains about the price of a new reel i buy "rather pay for quality than pay for another reel".
Stapies
Katot wrote:
James, my ou vriend. Jy gebruik te veel goed wat suck lyk dit my.
Hahahaha Willie, ek het meenigte stradics, 5000,8000, shimano symitres ens... Ook baie ander. En 'n saragosa 6000 wat opad is...
So dink nie dit suck nie. Dis net 'n quality issue en dis onaanvaarbaar dat 'n katrol so kalf... Hulle kan dit maar vervang...
Katot
Eerlik waar Okuma is nie sleg nie. Die trio is baie lekker vir rivier hengel. As jy kyk na iets in die Okuma range wat meer gepas is vir wat jy dit wil gebruik dan moet jy kyk na die Salina II of die okuma Raw/Cedros grinders. Vir wat jy betaal kry jy n goeie katrol.
Blikkiesvis
James, you must have the worst luck of all the fishermen I know... Either that, or your just the most vocal... If your not popping a power swiwel(that suck) or pulling a circle hook(that suck), your breaking a rod tip(that suck) or having a rusty grinder(that suck)...
Btw, with all the Shimano tackle you already have, you should know their quality, why buy anything else? Having said that, I suppose its your choice and has nothing to do with me... Maar, die oumense het geweet waarvan hulle gepraat het toe hulle gesê het..."goedkoop koop is duur koop"
Hope you luck changes! ;)
Bliksem
When buying for cheap, always, keep in mind... a quote from John Ruskin[highlight= #88FFFF][/highlight]
"It's unwise to pay too much, but it's worse to pay too little. When you pay too much, you lose a little money - that's all. When you pay too little, you sometimes lose everything, because the thing you bought was incapable of doing the thing it was bought to do. The common law of business balance prohibits paying a little and getting a lot - it can't be done. If you deal with the lowest bidder, it is well to add something for the risk you run, and if you do that you will have enough to pay for something better."
Having said that... ek het 3 Okuma multipliers (the old Convector/Contender series) wat ek al van 1998 gebruik. They did their fair share in fishing the Breede. Had a few minor issues like the chrome plating on the star wheel peeled; they replaced it FoC with an aluminium one, had some side cover screws rusting; was replaced FoC.
