Non Return slide
Dean Slater
depends, the weight helps by sliding down your line faster, so i use it when im sliding bigger baits, the weightless one, i prefer when im sliding a shy live bait ie mullet, shad and karras i use the live bait clip.
Atjie
Thank you for the info.
I also did some research and exactly as you said, from the beach with not much of an angle, you use the one with the weight and where there is a good angle you dont need a weight. But still it is personal choice.
Moyeni
If you are fishing for sharks and rays MAKE sure you use the HEAVY DUTY non-returns with the bead.
The standard small non returns tend to bend which CAN cause burn offs....
Atjie
Yes, the normal one without the bead bend relatively easy, I had some bend beyond re-use after not even a big shark.
steve m
imagine this slide didnt have a bead and a power swivel...
