Hi guys
I read on a website the following and like to share with the members.
Winding Line on the Machine at the tackle puts stain on you line and does not create the correct profile on your drum and therefore reduces your casting distance between 12 to 15 percent.
Suggestion is it is done manually with the following method
Drop your spool in a bucket with luke warm water and run you line to the middle of a telephone directory.The luke warm water adds lubrication.tension and softens your line.The directory puts the correct amount of tension. When your soften line seats itself on your line it is claimed that the memory retention is excellent reducing drag and bunching.
I would like to know if anybody has heard about or tried it
Jace
Jace
